Forums >> Revit Building >> Tips & Tricks >> Array without grouping
Mon, Jul 13, 2009 at 6:07:47 PM | Array without grouping
jarosa
jarosa Avatar
4 Stars: 5 Votes
This comes from the desk of "duh look at the options bar." I've never liked how arrays are always grouped. You can avoid this by clearing the group and associate box (on the options bar). BTW this will improve model performance.
FWIW,
John
Tue, Jul 14, 2009 at 4:53:48 AM | Array without grouping
4 Stars: 205 Votes
Thanks Jarosa....
Tue, Jul 14, 2009 at 8:54:48 AM | Array without grouping
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Good tip, thanks jarosa......
Tue, Jul 14, 2009 at 11:02:33 AM | Array without grouping
coreed
coreed Avatar
4 Stars: 16 Votes
if only Options worked that way in the Stock Market !! Smile
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Wed, Jul 15, 2009 at 9:33:26 AM | Array without grouping
rkitect
rkitect Avatar
4 Stars: 29 Votes
Note that it will increase model performance, but eliminate the option of making that array parametric.  So if there's a chance that something in that array may change, leave Group and Associate checked.
Mon, Jul 20, 2009 at 12:33:22 PM | Array without grouping
MARS1276
1 Stars: 1 Votes
rkitect has a very valid point.  I have created a metal roof panel (4' wide) and I assign the family a length.  When I do an array it groups each, but I have found in the recent past that it works nicely when I want to move or lengthen the panel; I do it to one group and the rest change as well, making less work on my part.
Mon, Jul 20, 2009 at 6:33:18 PM | Array without grouping
jarosa
jarosa Avatar
4 Stars: 5 Votes
Point well taken. Just an option for say a simple detail component that a user wouldn't probably change the family. But I guess that's why it's on the options bar.
John
Tue, Jul 21, 2009 at 7:46:03 AM | Array without grouping
rkitect
rkitect Avatar
4 Stars: 29 Votes
Yes, that's exactly what it is there for.  I hit that phase that you were in at one point where I started arraying things for detail components, then I found the "repeating Detail Component" tool Smile
Cheers!
Wed, Aug 19, 2009 at 4:18:03 PM | Array without grouping
Thread Post Kudo! #9
wsquiers
I have a question about grouping and arraying as part of a parametric model.  Typhoon has tried to help but apparently I'm not yet up to the task.  I have a louver model and want the blades to adjust with the size of the louver.  When I have a single blade I can attach it to the frame and everyone is happy when the louver size changes.  The second I try to array the blades and asign them a parameter things get wacky.  I attach the ends of the blade to the frame, array it and asign a formula for the number of blades.  When I change the louver width I get a message that the constraints aren't satisfied and the blades stay the same length.  Arraying the items screws everything up for some reason.
Grouping Floors
Mon, Aug 22, 2005 at 3:47:49 PM
how can I array along spline? [ 1 2 ]
Fri, Nov 28, 2008 at 7:07:32 AM
19
Array along a curved path
Tue, Nov 11, 2014 at 9:11:45 AM
2-dimensional Array of Arrays
Wed, Aug 3, 2011 at 7:47:12 AM
Parametric Array Constraints
Tue, Jul 2, 2019 at 7:00:45 AM
Page generation time: 7.2374
