15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> Yes / No Void
6 Posts No Rating |
I have created a VOID to a component but I want to allow flexibility of having it or not using a parametric radius. However, the radius cannot be zero to get rid of the VOID. Is it possible to use Yes/No Parameter to control its occurence? Or other ways can do and how?
Regards,
Not possible to turn the curve off, however you could set it up so you have a yes/no parameter for a curve then based on which selected you could create parameters that adjust the void so it doesn't cut the and straight line void cuts and vice versa...
6 Posts No Rating |
Thanks Mr Spot.
32 Posts No Rating |
I'm trying to create a seat for a precast double tee family by creating an void extsion running along each end of the tee. I set up some 'yes/no' parameters but I can't apply those parameters to the void extrusion. I made the family in the 'beams and braces' family template as well as the 'generic model line based' family template hoping the problem was the template, but it wasn't. Could someone tell me how to apply the yes/no parameter to a void extrusion? Thanks
Can't but read my post in this thread for how yoiu can do this. http://www.revitcity.com/forums.php?action=viewthread&thread_id=17452
50 Posts No Rating |
You can't use a yes/no visiblity parameter with a void. You might need to find a work-around so you do not need to use the void.
14 Posts No Rating |
I learned this in AU ad David B's class on fuzzy math for families. He did not use the parameter to turn off the void but to move it out of the way it is intersecting. used it to create window in doors as a yes no.... so the yes/no parameter just added X' to the location of the depth of it so it effectively pushed it away from the mass it is cutting. -
Void Masses |
Fri, Oct 3, 2008 at 4:11:06 PM
void in family is yellow |
Mon, Mar 12, 2018 at 12:22:43 PM
Void Sweeps |
Thu, Nov 24, 2005 at 10:31:45 PM
Moving Void Forms |
Thu, Feb 3, 2005 at 5:39:37 PM
Selecting Invisible Void Sweeps |
Wed, Jan 28, 2009 at 4:23:09 PM
