Forums >> Revit Building >> Technical Support >> "Squiggled lines" in Revit
Mon, Jul 13, 2009 at 4:55:11 PM | "Squiggled lines" in Revit
epepa
In Autocad there is a command to create a "napkin sketch" based on and elevation or plan view. Is there a similar command in Revit (either 09 or 10) to take a view and "process" it to look like it is a hand-drawn sketch?
Mon, Jul 13, 2009 at 5:05:44 PM | "Squiggled lines" in Revit
need4mospd
If you're on the Autodesk subscription service, check out Autodesk Impressions for sketchy stuff.
Tue, Jul 14, 2009 at 11:06:14 AM | "Squiggled lines" in Revit
coreed
coreed Avatar
4 Stars: 16 Votes
No, you will have to export as dwg. then do your magic in some other program(Autocad,SketchUp etc.).
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Tue, Jul 14, 2009 at 11:42:43 AM | "Squiggled lines" in Revit
epepa
Thanks to both replies. I ended up downloading Impressions because we have a subscription. This is EXACTLY what I've been wanting. Only too bad that it doesn't link directly to a Revit drawing so updates could be automatic.
Mass and walls are squiggled
Tue, May 5, 2009 at 2:23:00 PM
Imported Cad Lines not "live" [ 1 2 ]
Fri, Aug 15, 2008 at 2:02:40 PM
15
Laser plotter makes raster images look "screened"
Wed, Aug 5, 2009 at 6:07:30 PM
changing the "family" and "type" names
Mon, Apr 2, 2007 at 5:33:49 PM
When I copy an "existing" element it reverts back to "new construction."
Mon, Jun 16, 2008 at 2:38:24 PM
Page generation time: 4.6271
