Forums >> Revit Building >> Technical Support >> Column sizes in the Drawing List
Mon, Jul 13, 2009 at 1:27:29 PM | Column sizes in the Drawing List
Hurtman1963
I am working on a cover sheet for our company and figured out the drawing list and all the formatting issues except one.  I brought the drawing list into the cover sheet and I am wondering how I can make the columns wider, especially for the drawing name so that it does not put it onto two lines.  Thanks.
Mon, Jul 13, 2009 at 1:42:32 PM | Column sizes in the Drawing List
On the sheet - click on the schedule then grab the grip and size your column as you want it visually.
Mon, Jul 13, 2009 at 2:11:17 PM | Column sizes in the Drawing List
Hurtman1963
Thanks.  Got that to work.  How about row height?  I have been reading on here where there is no way to adjust the row height to fit on an existing grid.  Is that still the case?
Mon, Jul 13, 2009 at 2:24:16 PM | Column sizes in the Drawing List
What you will find with REVIT is that most things are straight forward.  That is, the options you have are the ones shown and/or shown in the HELP.  There is no listing for this in either of those areas.
Adding a check box list to a drawing list
Thu, Apr 21, 2016 at 5:17:56 PM
Revisions in Drawing List
Tue, Mar 6, 2012 at 2:37:26 PM
newbie: workflow for custom column sizes in a measured building survey?
Tue, Feb 10, 2009 at 9:53:03 AM
Revit Drawing List
Tue, Mar 15, 2011 at 5:20:07 PM
Splitting Drawing List and Door Schedule...
Thu, Jun 10, 2010 at 3:08:27 PM
Page generation time: 0.2557
