Forums >> Revit Building >> Technical Support >> Scope of Work Schedule (room reference tag)
Mon, Jul 13, 2009 at 8:01:06 AM | Scope of Work Schedule (room reference tag)
shadow7
I need a method that will allow me to craft a scope of work within REVIT that can be exported or linked to an Excel spreadsheet or directly copied into Word report for further use of information.
Each item would be scoped using a noteblock or keynote tag, so I can show the item reference on the drawing.  The item reference must able to reference the room is placed within, similar to a door tag.
Would this best performed from or with what tag, note block or keynote?
Brainstorm: Revit Excel Based / Generated Tag or Note
Or a Keynote that recognizes what room it is in - Room Reference
Room Number Room Name
Item# Floors Description Cost
Item# Walls/Col. Description Cost
Item# Windows Description Cost
Item# Doors Description Cost
Item# Electrical Description Cost
Item# HVAC Description Cost
Item# Plumbing Description Cost
Item# Spec.Const. Description Cost
Item# Misc. Description Cost
 Thanks.
Making a Room Tag that will show a Calculated Value from a Room Schedule.
Tue, Jan 25, 2011 at 5:32:37 PM
How do I combine fields in a note block with fields in a room schedule?!?
Thu, Mar 4, 2010 at 3:51:58 PM
Tag room schedule key info
Wed, Sep 11, 2013 at 11:13:01 AM
automating door schedule ( From room # To Room #)
Thu, Jun 20, 2019 at 2:14:07 PM
Abbreviating Room Tag Names vs. Schedule
Thu, Sep 1, 2011 at 2:05:14 PM
Page generation time: 0.8848
