Forums >> Revit Building >> Technical Support >> ARCH Model and STRUCT Model in the Same File
Sat, Jul 11, 2009 at 9:47:41 AM | ARCH Model and STRUCT Model in the Same File
SJkachmar
 Hello. I am working on a Small (6000 sq. ft) Residence in revit 2010 and our Structural engineer does not use Revit. My office asked me to build
the Architectural Model and the Structural Model in the Same file, really virtually prototyping the home. I'm installing all the TJI's
 Structural Columns, Roof Rafters, the File seems to be getting a little sluggish, but overall its working out ok. Does anyone else have experience
with this way of doing a project, and would anyone reccomend splitting the files and linking them instead of keeping them in the
same file? thanks for any comments and ideas
  -Sam
 "Wherever you go, there you are"
Sun, Jul 12, 2009 at 1:10:48 PM | ARCH Model and STRUCT Model in the Same File
I've got to believe that on this project you should be just fine but I know nothing about your system because you don't give that information.
Sun, Jul 12, 2009 at 1:36:35 PM | ARCH Model and STRUCT Model in the Same File
SJkachmar
my system is a Dell Computer with Intel dual Quad Core Processors 2.8 GHZ, running Windows XP 64-bit, currently with 4 GB of Ram and should
be upgrading to 8 GB this week, Thanks for your input, some people seemed fearful of placing a structural and architectural file together.
 the Legal responsibility aspect could get vague, but our structural Engineers are in house, so hopefully that should alleviate that problem.
 thanks again
  -Samuel
Sun, Jul 12, 2009 at 1:52:39 PM | ARCH Model and STRUCT Model in the Same File
lunchtrayrider
3.5 Stars: 7 Votes
use worksets to speed things up.
Mon, Jul 13, 2009 at 6:49:42 AM | SJkachmar
coreed
coreed Avatar
4 Stars: 16 Votes
Quoting SJkachmar from 2009-07-12 13:36:35
 thanks again
  -Samuel
go to 8 GB as soom as possible. 4GB is not enough for this OS system and Revit.
hth
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Linking Arch file into Struct and using Arch groups?
Tue, Jan 18, 2011 at 7:44:19 AM
We have >2K cols in proj. How can we replace our arch. elements 4 struct. ones
Mon, Dec 12, 2011 at 4:05:12 AM
Structural walls in Architectural Model
Fri, Aug 6, 2010 at 9:51:37 AM
How should links be loaded into a main model file? <Noob question>
Fri, Dec 9, 2011 at 8:42:52 AM
updating a revit arch model error (REVIT 12)
Fri, Mar 1, 2013 at 4:06:42 PM
Page generation time: 4.7343
