Forums >> Revit Building >> Technical Support >> Wall ends
Mon, Aug 1, 2005 at 4:18:58 AM | Wall ends
cadjockey
Hi All, I have created a custom wall by altering it's properties, integrating two sweeps so that a particular wall corbel and skirting appear whenever I place this type wall. However, the profile of the corbel and skirting do not wrap around the wall at it's end or when the wall forms a clear opening. How do I get around this challenge? cadjockey
Mon, Aug 1, 2005 at 7:36:14 AM | RE: Wall ends
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Select the wall, you'll notice you get an option to edit the returns. Click on the end of the sweep to have it return at the end or opening and drag around to have it wrap. HTH.
Mon, Aug 1, 2005 at 10:05:58 PM | RE: Wall ends
cadjockey
Hi Mr Spot, I see. However, how do I get the sweep to return all the way across the wall end and not just within it's own depth? cadjockey
Mon, Aug 1, 2005 at 10:10:55 PM | RE: Wall ends
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You missed what i said above... after doing this drag the end point around this corner of the wall to have it extend as far as needed.
Mon, Aug 1, 2005 at 11:53:50 PM | RE: Wall ends
cadjockey
Hi Mr Spot, Thanks, it's working fine. I couldn't see the handle to drag the sweep across. Thanks for your patience and help. cadjockey.
non orthogonal wall ends
Wed, Jul 18, 2007 at 12:51:57 PM
Wall Ends No going to Gridlines
Fri, Apr 9, 2010 at 2:04:02 PM
Adjust Wall Ends
Wed, Jul 10, 2013 at 9:08:25 AM
REVIT 2013 - Angled Layered Wall Ends
Tue, Dec 3, 2013 at 8:18:33 AM
Wall Sweep Return Ends
Sun, Sep 11, 2005 at 11:55:27 AM
Page generation time: 0.4952
