Forums >> Revit Building >> Technical Support >> Showing Shadows from a building when the building is behind the elevation line.
Thu, Jul 9, 2009 at 11:00:15 PM | Showing Shadows from a building when the building is behind the elevation line.
SallyWilliams88
Hi,
 Can you have a shaddow casting from a building/element when the building/element is behind the elevation/section line?
Sun, Jul 12, 2009 at 12:52:56 PM | Showing Shadows from a building when the building is behind the elevation line.
4 Stars: 205 Votes
Did you try it???
Sun, Jul 12, 2009 at 8:02:41 PM | Showing Shadows from a building when the building is behind the elevation line.
SallyWilliams88
Hi,
 Yes i did and no luck! I thought there might be a trick to showing shadows from other elements not in the view?
Elevation Shadow Diagrams
Mon, Jun 3, 2013 at 12:02:47 AM
Elevation Shadows
Sun, Jun 2, 2013 at 11:46:24 PM
Shadows on Neighbouring Building Elevations
Fri, Sep 7, 2018 at 3:54:42 AM
How to cast a shadow from the building element behind a section/elevation line
Sun, Feb 18, 2007 at 9:40:29 PM
Wall Sections Showing up on Both sides of building
Wed, May 8, 2013 at 4:13:39 PM
Page generation time: 0.6893
