Forums >> Revit Building >> Technical Support >> How To Change Railing Materials
Thu, Jul 9, 2009 at 2:20:50 PM | How To Change Railing Materials
kyleduke
Hello,
 I have created a new railing system (Revit 2010), but cannot change or edit the material of the balusters or post that I made as new families. I can change the hand rail material, since there is a material tab for that one in the type properties. I have tried going back into the family editor for the balusters but the material parameters that I create do not show up anywhere when I bring it into the main file. Any ideas on how to fix this would be greatly appreciated. Thank you.
Thu, Jul 9, 2009 at 2:48:39 PM | How To Change Railing Materials
Find your balluster in your browser under railings... right click on the type and set the materials there.
Thu, Jul 9, 2009 at 2:54:23 PM | How To Change Railing Materials
kyleduke
Hello again,
 I found the way to do it finally. Not very logical, but it works. This is from another member. Thanks.
"you have to go through the Project Browser... go to 'Families' ... Then go to 'Railings' Right click on the size baluster you want to change material and BAM!"
RAILING MATERIALS ?? HELP
Tue, Oct 7, 2014 at 6:18:39 AM
rectangular railing
Mon, Nov 26, 2012 at 7:30:07 AM
Railing
Wed, May 30, 2012 at 10:16:19 AM
Material schedule not picking up materials in railing object
Fri, May 6, 2011 at 4:03:35 PM
Assigning material to rails
Fri, Oct 12, 2012 at 12:34:24 PM
Page generation time: 1.3954
