Forums >> Revit Building >> Technical Support >> twisted baluster family
Sun, Jul 31, 2005 at 11:57:42 PM | twisted baluster family
nandini
how do we create a twisted baluster?
Mon, Aug 1, 2005 at 12:01:06 AM | RE: twisted baluster family
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You could you a series of blends place on top of each other...
Mon, Aug 1, 2005 at 11:27:21 PM | RE: twisted baluster family
nandini
hi mr.spot. i remember that at some point in time while creating the baluster there is an option checking which we are able to twist the rod. am not able to place it. can you help and pick at that?
Tue, Aug 2, 2005 at 1:30:37 AM | RE: twisted baluster family
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Yes using the blend tool there is an option when sketch the top or bottom profiles to twist. This basically allows the selection of which vertices top and bottom are to connect. But personally if the twist is how i envisage it to be i would just rotate the profile 180º and then systematically rotate and place on top until you've reached the desired height.
Tue, Aug 2, 2005 at 8:16:59 AM | RE: twisted baluster family
nandini
thanx! got exactly what i was looking for!
twisted/slope/curve roof
Thu, Oct 19, 2006 at 7:26:04 PM
rail 1 and baluster heigth
Tue, Nov 8, 2011 at 10:40:22 AM
custom baluster with decorative piece not staying equal 2019
Thu, Jun 14, 2018 at 1:54:47 PM
Baluster Family Help
Thu, Oct 16, 2014 at 11:15:48 AM
Baluster Height Issue
Tue, Nov 6, 2007 at 6:37:15 PM
Page generation time: 2.3299
