Forums >> Revit Building >> Technical Support >> Change Project Brick size!
Wed, Jul 8, 2009 at 4:54:20 PM | Change Project Brick size!
ksmith
Did a search but can't find the answer to this. My default brick size in my project at present is 75mm which I am assuming is also taking into consideration a 10mm mortar joint. Please correct me if I am wrong!!
I would like my default brick size for my current project to change from 75 mm to 85 mm, thereby accommodating a 10 mm mortar joint.
Is it possible to make this change please or am I asking too much from Revit?
Using revit 2010
Many thanks
Kirk
USING REVIT 2011--- This old builder is determined to Learn Revit no matter what it takes.
Thu, Jul 9, 2009 at 7:26:40 AM | Change Project Brick size!
Answer to your question - yes, you can change..
Now ... what you should have included in your question.  Are you talking about brick detail components, hatch (fill) patterns or material bitmaps?
Thu, Jul 9, 2009 at 3:31:21 PM | Change Project Brick size!
ksmith
I guess it will be more brick detail. All I'm really after is being able to change the size of the brick in order to be able to get more accurate scaling in my drawings. So yeah, if it can be done, please tell!
Many Thanks
Kirk
Thu, Jul 9, 2009 at 4:48:58 PM | Change Project Brick size!
If you don't have the correct brick detail size.  Just edit your brick detail family ...and then edit your repeating detail - both to match the brick and mortar you are using.
Thu, Jul 9, 2009 at 5:33:31 PM | Change Project Brick size!
tim123
4 Stars: 19 Votes
In the UK, the standard brick size is 65mm, so the fill pattern in the default pattern is correct, as is the repeating detail for brick Crying65mm + 10mm mortar).  As WWHub, says these can both be adjusted, if required.  With regard to the material, you may need to fiddle with them a bit to get them to align with the fill pattern correctly, but it can definitely be done.
Thu, Jul 9, 2009 at 5:45:06 PM | Change Project Brick size!
ksmith
Many thank to both of you. I will have a tinker.
Brick Colour
Mon, Jan 13, 2014 at 9:27:03 AM
I can't change the connecor size. It stays on -609.6 mm
Mon, May 18, 2015 at 7:06:40 AM
Question regarding mulitple brick veneers.
Tue, May 5, 2015 at 10:15:35 AM
Material Pattern with Solid Surface Color
Mon, Apr 27, 2015 at 6:11:02 PM
Window Family with Different Size Opening Cut
Thu, Aug 25, 2011 at 7:16:41 AM
Page generation time: 0.9492
