Forums >> Revit Building >> Tips & Tricks >> Revit TotD – 7.8.9: Glowing Signage, Image Based
Wed, Jul 8, 2009 at 1:52:46 PM | Revit TotD – 7.8.9: Glowing Signage, Image Based
rkitect
rkitect Avatar
4 Stars: 29 Votes
Yesterday I had fun exploring self-luminance issues with a fellow revitcity.com member.  In trying to decide the best method for creating glowing signage, we came up with two really fun ideas for dealing with signage depending on your situation.  I'm going to split them into two tips because they each take quite a bit of work to accomplish.  So let's begin shall we?
Today's situation is the need to create a glowing sign using an image that you are provided.  You could try to model the image if you are talented, but if you are in a hurry and just need something fast, you can follow these quick steps to create a nice glowing banner.  Note that this is not the method to use for individual letter signs that you would see, say for instance spelling out "Regal 10" down the monument sign in front of a theater, but instead something like, well you'll see...
Creating the Light Fixture:
  1. For my example I am using the Linear Light Fixture Wall Based family template.  Use whichever template is most appropriate for your sign.
  2. I'm not going to cover the creation of the fixture itself, just point out some important features to pay attention to:
    1. Axis intersection defines light source origin.
    2. The photometrics of the light adjust the luminance and falloff of the light source, adjust these to tweak the light output of your sign.
  3. For the light fixture in this example, I have modeled an extrusion to serve as the surface for our Sign image.
  4. Create a subcategory for your Banner so we can apply the material once the fixture is in the project. (NOTE: If you will have multiple signs, you will want to create an instance material parameter to assign the material to the banner per instance in the project instead of assigning a material via object styles)
  5. Now that you have your fixture made and the surface for the sign set to the proper object style subcategory, load the Fixture into your project!
Creating the Material:
  1. After placing the fixture in the project, you will be able to access the object style we created through the Manage > Settings > Object Styles menu.
  2. Assign a material to the Banner Object Style we created in the family.
  3. Create a material for the Banner by duplicating an existing material.  It doesn't matter which since we'll be changing several things.
  4. Under the Render Appearance tab, click Replace, next to the "Based on" material image and name.
  5. Search for "LED" with the Class set to "".  You should see several options that indiciate on and off variations of LED colors, pick one and hit ok.  This example uses the Green On LED.
  6. There are a few parameters here that will need to be tweaked to get your sign looking good.  They include:
    1. Color: change to Image file to include your image on the sign
    2. Brightness: (only appears after you choose "Image File" in the color parameter) Sets the brightness of your image.  Tweak this till you get it to look the way you want.
    3. Transparency: 0 = Opaque, 1= Transparent
    4. Self-Illumination: Experiment with this setting, I've found that for images, the best setting is "No Self-Illumination"
    5. Bump: you probably don't need a texture, but if you do, here is where you should include it.
  7. Once you have your material set up the way you think looks decent, click OK till you are back to the model, then render it.  Be sure you have Artificial lights turned on in the Lighting settings.
  8. Tweak your material and light output settings as needed to create the glow you need for your sign.  remember, this takes time to perfect, so don't be surprised when you realize you just spent 2 hours getting this to look just the way you want.
Well that concludes another TotD.  Man was it an involved one.  I hope it has been benificial to you in some form or fashion.
Until next Revit TotD, thanks for stopping by, and see you then!
Remember that you can see this tip in its entirety with images and video at: http://revittotd.com/07/439
-Carl
revit_arch_09_cert_pro_rgbEdited on: Wed, Jul 8, 2009 at 1:53:18 PM
Edited on: Wed, Jul 8, 2009 at 1:56:32 PM
Revit TotD – 7.9.09: Glowing Sign, Self-Illumination Based Materials
Thu, Jul 9, 2009 at 2:20:36 PM
Attaching Signage to pannels??
Thu, Aug 10, 2006 at 12:45:22 AM
Revit TotD – 10.12.09: Revit’s “Center” Command
Mon, Oct 12, 2009 at 10:56:00 AM
Render has glowing walls 2012
Thu, May 16, 2013 at 1:18:58 AM
Revit TotD – 2.19.10 | Dimension Formulas
Fri, Feb 19, 2010 at 10:29:46 AM
Page generation time: 2.2263
