Forums >> General Discussion >> Wishlist >> Model for back to back water closets
Mon, Jul 6, 2009 at 10:53:50 AM | Model for back to back water closets
tylerbo
Has anyone found a way to model waste for banks of back-to-back water closets with a single drop through the floor in revit 2009?
Sun, Jul 12, 2009 at 12:56:17 PM | Model for back to back water closets
4 Stars: 205 Votes
Like what?? images please....
Mon, Jul 13, 2009 at 9:30:26 AM | Model for back to back water closets
tylerbo
http://www.jrsmith.com/products/closet/0175_0185.htm
this is the product type I am trying to model
Thank you for helping.
Mon, Jul 13, 2009 at 12:17:02 PM | Model for back to back water closets
I don't use MEP but can't you just model this with a nested family that has onew of your connections and the main family having the rest?
Mon, Jul 13, 2009 at 3:17:40 PM | Model for back to back water closets
tylerbo
The special fitting shown in the previous post is something we are trying to model.  In attempt to do so we tried using the attached fitting below and modifying it by rotating one of the elbows 90 degrees around the central axis.  The issue is that revit tells us the part can not be rotated due to the current workplane.  Attempting to add a connection seems to require a workplane perpendiular to the two workplands that already exixst in the fitting.  Constructing a plane in the third dimension seems to be prohibited by the program.
Mon, Jul 13, 2009 at 3:28:43 PM | Model for back to back water closets
tylerbo
I apologize, but the printscreen does not appear to work, here is the location of the part mentioned above.
Imperial Library>Pipe>Fittings>Crosses>Pipe Fixture Fittings-Glued
Mon, Jul 20, 2009 at 6:18:24 PM | Model for back to back water closets
tylerbo
Recently, due to a lack of ideas, I tried building a 'pipe box.'  Or simply a box with pipe fittings placed on all 6 sides, which could possibly be used as a model, given the right scale.  I was able to build the box, with the pipe fittings, but once I saved it, as it's own family, I tried to import it into the current project, revit told me I needed to click on a wall to place the item.   But, like revit is, revit would not allow to select the walls.  Does anyone know why this is?
Tue, Jul 21, 2009 at 6:40:30 AM | Model for back to back water closets
Are you using copy monitor?
If you are building your family using a wall hosted template, you have to own the wall.  That means you have to copy it.  An alternative is to use a face based family.
Tue, Jul 21, 2009 at 10:32:00 AM | Model for back to back water closets
tylerbo
Could you please go into more detail about exaclty what I need to do with the hall hosted template and face based family, I'm not sure how to do that.  Thank you
Tue, Jul 21, 2009 at 4:37:08 PM | Model for back to back water closets
tylerbo
I finally got something that was what I was looking for I will try to include the file with this reply.  Only a couple more questions.  How do I make this model so that it does not require a wall?  And how do I place a seventh pipe connector on one of the faces, but without it being centered?  I've tried just 'moving it' with the mouse, but the connector only wants to rotate, not move.  Anyone have any ideas?
Wed, Jul 22, 2009 at 4:32:41 PM | Model for back to back water closets
#11
LCreelman
The way you are making the part is incorrect. Revit wants an extrusion to add the pipe connector to. The pipe connection is centered on the extrusion so if you want to offset the pipe connection you must offset the extrusion see the attached modified file from yours.
Remove Model Filled Region @ Fixtures
Wed, Aug 15, 2012 at 4:19:33 PM
Squatting Water Closet
Wed, Dec 7, 2011 at 11:31:34 AM
Revit to Ram and back
Fri, Jun 3, 2011 at 4:07:47 PM
BACK 2 BACK TEXT IN RENDER
Tue, Jan 11, 2011 at 2:46:29 AM
Moving Design Options Elements Back To Main Model
Mon, Jun 15, 2015 at 1:57:58 PM
Page generation time: 1.4171
