Forums >> Revit Systems >> Technical Support >> Locking electrical components to host
Mon, Jul 6, 2009 at 8:19:45 AM | Locking electrical components to host
patrickj75
In Revit 2010 MEP I'm trying to get my electrical receptacles/switches to lock to the host wall. When the arch. dept. moves their walls my components aren't moving with it. Is there a default setting for fix this or something I need to do when i insert the component?
Mon, Jul 6, 2009 at 8:35:29 AM | Locking electrical components to host
Are you using face based families?  - Obviously not.
You might try the align and lock tool if you have something in the family to align with.  Did you try the "moves with nearby elements" switch?
Mon, Jul 6, 2009 at 9:13:42 AM | Locking electrical components to host
patrickj75
I'm using components from Revit so I assumed they were face based. I've been aligning and locking my components, just looking for a solution when I insert them the first time.
No, I have't tried "moves with nearby elements" switch. How do I do that? Can I just window my whole drawing to get all my components selected?
Mon, Jul 6, 2009 at 9:50:19 AM | Locking electrical components to host
Look on the options bar after you click on a component.  The "moves with nearby elements" switch is there.
Mon, Jul 6, 2009 at 10:44:38 AM | Locking electrical components to host
patrickj75
I don't have that on my toolbar.
Mon, Jul 6, 2009 at 11:39:37 AM | Locking electrical components to host
You must be using annotations....
The option is there for families - not annotations and it is not a tool - it shows up on the options bar after you select a model element.
Tue, Jan 12, 2010 at 12:46:36 PM | Locking electrical components to host
rebcampbell
Patrickj75,
 Did you ever figure out how to resolve this problem because I am having the same issues everytime we reload the architects revit model.  The walls move, but my electrical devices dont.
Tue, Jan 12, 2010 at 1:08:57 PM | Locking electrical components to host
patrickj75
No, I never did get it figured out.
Wed, Mar 31, 2010 at 3:18:03 PM | Locking electrical components to host
rebcampbell
I found out that the architect was deleting their walls and re-drawing them instead of just moving the walls.  since the my elements were hosted to the wall that was deleted, it was no longer hosted.  I just had to talk with the architect and make sure that instead of deleting walls, they edit them and move them in order for my elements to move with them.
Electrical components moving when reloading arch model
Mon, Jan 5, 2015 at 9:01:02 AM
Electrical devices not hosting??
Thu, Jun 11, 2009 at 10:43:01 AM
Electrical plan
Tue, Dec 20, 2011 at 10:52:41 AM
Electrical detail components
Tue, Sep 8, 2009 at 12:05:24 PM
Import/Linking Excel Sheets into Electrical Components
Wed, May 20, 2009 at 9:45:53 AM
Page generation time: 5.0270
