30 Users Online (28 Members):
Forums >> Revit Building >> Technical Support >> Multiple Profiles in a Sweep
2 Posts No Rating |
Where or is it possible in revit to create a sweep that has multiple profiles to it?
49 Posts No Rating |
How would it work to have multiple profiles? What are you actually trying to do? If you mean that want the sweep to change from one profile to another at some point along its path then you will have to do two separate sweeps end to end.
Cheers!
No blended sweeps are not yet possible in revit.
17 Posts No Rating |
So how about mass and void in a roof? I've got a curved-profile roof, but there's a portion that extends out farther on the ends than it does in the middle (see screenshot); must I make more than one roof surface to satisfy this requirement, or can I make it one, lovely, sweeping curve that happens to have a notch in it? Thanks, -r
Sweep Profiles in Version 9 |
Thu, Aug 3, 2006 at 2:14:05 AM
MULTIPLE MATERIALS WITHIN SWEEP PROFILES??? |
Mon, Aug 25, 2008 at 2:57:30 PM
Multi-profile Sweep |
Fri, Jan 22, 2010 at 8:08:14 AM
Blend sweep problem |
Tue, Feb 28, 2012 at 1:51:35 PM
Profiles on a meandering sweep. |
Thu, Jan 27, 2011 at 12:50:57 PM
