15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> Memory Hog
49 Posts No Rating |
When I start a rendering in revit while processing the voxel and screen space my free memory drops from 1.6 gigs or so to about 150 megs. If I do the rendering at a good quality then revit will crash, if I do it at a lower quality it will sometimes finish the rendering. When it does finish and I export the rendering, my memory is still down about about 500 megs (after pressing display model). Is there a way to free up my memory without having to close the project after every rendering? And is anyone else having problems with revit using hella much more memory than it should need to?
Cheers!
Okay im not sure what happened... but I was fiddling around with a whole bunch of settings and my rendering seem to be working great now! I think one issue might have been that the ground plane was set way below the xy plane so maybe it had to calculate all the way down or something. But whatever it is I getting some pretty high quality renderings and not nearly so much ram usage!
Cheers!!
if you watch your ram/cpu/hdd usage while you are rendering you will see it's all cpu..
Revit MEP computer hog |
Fri, Mar 28, 2008 at 8:02:23 AM
I have enough memory but Revit doesn't agree about that |
Sun, May 10, 2015 at 10:59:23 PM
2009 memory requirements |
Thu, Jul 10, 2008 at 4:08:14 PM
x64 OS and 12 G of memory? |
Mon, Aug 24, 2009 at 3:59:15 PM
Out of Memory |
Mon, Apr 29, 2019 at 4:10:05 PM
