Forums >> Revit Structure >> Technical Support >> View setting for wall joins display
Wed, Jul 1, 2009 at 3:00:12 AM | View setting for wall joins display
ameschan
Hello!
I would like to change wall joins display settings in view properties. As I read from Revit help (see first attached picture), it would be possible to change this to "clean same type wall joins", but as you see from my second attached picture, option for changing wall join display is not available (light gray). The problem is that Revit cleans all wall joins, så I have to change a lot of wall joins after that (see third attached picture).
Please, any suggestions?
Edited on: Wed, Jul 1, 2009 at 3:03:03 AMEdited on: Wed, Jul 1, 2009 at 3:04:09 AMEdited on: Wed, Jul 1, 2009 at 3:05:02 AM
Edited on: Wed, Jul 1, 2009 at 3:07:02 AM
Wed, Jul 1, 2009 at 3:05:56 AM | ameschan
ameschan
2.picture
Edited on: Wed, Jul 1, 2009 at 3:07:32 AM
Wed, Jul 1, 2009 at 3:06:33 AM | ameschan
ameschan
3.picture
Wall Join Display
Thu, Oct 14, 2010 at 12:52:50 PM
Any way to set Wall Join Display to not clean any walls?
Mon, Sep 19, 2011 at 1:19:19 PM
Does anyone else wish that there was a toggle to make wall joins the default off
Wed, Aug 19, 2009 at 9:49:42 AM
Compound wall joins do not display correctly
Tue, Jun 14, 2005 at 12:26:07 PM
Wall Join Options Disappear [ 1 2 ]
Tue, Apr 23, 2013 at 3:45:22 PM
26
Page generation time: 4.9616
