Forums >> Revit Building >> Tips & Tricks >> Revit TotD – 6.30.09: Room Tag Types “I don’t have that option!”
Tue, Jun 30, 2009 at 5:14:23 PM | Revit TotD – 6.30.09: Room Tag Types “I don’t have that option!”
rkitect
rkitect Avatar
4 Stars: 29 Votes
As usual, this tip is the result of coming across another odd "I don't have that option" when trying to help another fellow revitcity.com member.  When he asked about how to show the Volume and are information in his room tags, I simply remarked that he should choose the correct Room Tag type from the Type selector.  When he said he did not have that option, I went through painstaking detail to explain to him where the type selector was and how to change the types, only to find out that the metric room tag family does not have those options.  Surprised, not really.  So here are the steps I gave him to modify his room tag to display this information.  This can be used for any annotation family that you wish to modify to show information you wish to show.
View demonstration video here: http://revittotd.com/revit/video/TotD-6.30.09-RoomTagLabelVis.swf
Modifying your Room Tag labels and types:
  1. Select the room tag and click "Edit Family."  Alternatively you can open the family directly if you know where it is located.
  2. In the family you will see what labels are already in place.
  3. Place the new Labels.
    1. Choose the Label tool.
    2. Click to position the new label.
    3. Select an available category parameter to be included in the label and move it to the right.
    4. Click OK
    5. Repeat for all new labels.
  4. Click "Types" to access which types are available.
  5. Create the parameters for the visibility controls that we will associate to the new Labels.  In this case we are crating tag types that will individually show Room Name; Name and Number; Name, number and Volume and finally Name, Number and Area.  So we need 4 yes/no parameters in this case.
    1. Create New parameter,
    2. Name it according to which label it will be controlling.
    3. Choose "Yes/No" from type.
    4. Choose the appropriate group for your parameter.  In this case it will be Graphics.
    5. Leave it as a Type parameter since the family type will be controlling the parameter.  Click OK to create the parameter
    6. Repeat for the remaining parameters.
  6. Create the 4 types.
    1. Change the parameters to show the correct setting for the new type we are about to create.  In this case, Name, Number and Area.
    2. Click New under types.  Name the Type accordingly.  Click OK.
    3. Repeat these steps for all types.
  7. Associate the parameters to the object's visibility parameter.
    1. Select the Label and open it's properties.
    2. Choose the "=" button to the right of the "Visible" parameter.
    3. Choose the appropriate parameter to control that label's visibility, in this case, the Volume parameter we created.
    4. Click OK
    5. Repeat for all labels that need visibility associations.
  8. Load the new tag into the project.
  9. Notice that you now have the 4 types we just created available in the type selector.
  10. Test the new family to ensure all types work appropriately.
While I wasn't surprised to learn that the Metric install of Revit omitted these types from the family library, I was sure disappointed.  Either way, I hope this has been helpful to you.  Remember you can apply this to most annotation families that you wish to alter the information shown for your projects.  Remember that you also will want to save the new family in a different location than the default family location so that you don't overwrite the default tag.  Thanks again for stopping by, have a great day and I'll see you again for the next Revit TotD!
As usual, you can see this tip in its entirety at http://revittotd.com/06/403
Enjoy!
Edited on: Tue, Jun 30, 2009 at 5:17:20 PM
Revit TotD – 7.29.09: Don’t Skip the SKP Mats
Wed, Jul 29, 2009 at 9:24:55 AM
Room Tag Family Question
Tue, Sep 25, 2007 at 9:49:35 AM
Room tag not showing in only one room. [ 1 2 ]
Sat, Sep 27, 2025 at 3:40:00 AM
15
Visibility elements in a room tag
Mon, Aug 9, 2010 at 2:58:33 PM
Leader line position from Room tag
Thu, Aug 9, 2007 at 6:44:38 PM
Page generation time: 1.6259
