Forums >> Revit Building >> Technical Support >> FAMILY WORKS IN EDITOR BUT NOT IN PROJECT
Tue, Jun 30, 2009 at 2:06:56 PM | FAMILY WORKS IN EDITOR BUT NOT IN PROJECT
adeuley
I made a projector and screen in the family editor. When I move things in there everything works. For example the screen case is mounted in the ceiling and the the screen height is actually based off the bottom of the image height which is a certain height above the floor. I want the screen height to change when i change the image height of the floor. I flex the object in the family editor and everything works perfectly. I place it in the project. I align the top of the screen with the ceiling and then try to align the bottom of the screen with the floor, just to see if it will move, and nothing happens. Any ideas?
Tue, Jun 30, 2009 at 2:40:35 PM | FAMILY WORKS IN EDITOR BUT NOT IN PROJECT
From your question, I think you need to spend some more time with your family building tutorials.  Work on understanding the use of parameters and labels.  You can read a lot in your HELP if you look under labels.
Read Dimensioning with Families Tips  - Dimensioning with Families - Instance Parameters and Shape Handles
Family Editor Commands
Family Editor: works... then doesn't!
Fri, Sep 2, 2005 at 5:23:05 PM
Saving a family fom project to family editor
Fri, Sep 17, 2004 at 6:39:40 PM
Draw Order in Family Editor
Wed, Aug 28, 2013 at 3:07:31 PM
Updating materials in family editor not updating project.
Thu, May 16, 2019 at 12:22:46 AM
adding mass in family editor or in place family creation
Thu, Nov 23, 2006 at 9:52:52 AM
Page generation time: 4.9311
