Forums >> Revit Building >> Technical Support >> 2009-Topo & Pad...anyone has an idea
Tue, Jun 30, 2009 at 6:12:35 AM | 2009-Topo & Pad...anyone has an idea
Pavan
Pavan Avatar
4.5 Stars: 3 Votes
Please see the attached image and can any one has an idea or solution for this kind of requirement. My topo shouldn't enter the building but should toucht he exterior face of the wall at the top.
Pavan Reddy
Revit Manager
Intelligence is not always knowing the answers, it's always asking the questions.
Tue, Jun 30, 2009 at 6:39:28 AM | 2009-Topo & Pad...anyone has an idea
4 Stars: 205 Votes
The situation is right, the Pad Cut the topo Vertically, what you can do is create an "extra" topo surface in top of that and create a masking region like i put in the image attached...
Edited on: Tue, Jun 30, 2009 at 6:42:03 AM
Tue, Jun 30, 2009 at 11:33:25 PM | 2009-Topo & Pad...anyone has an idea
Pavan
Pavan Avatar
4.5 Stars: 3 Votes
Hey Typhoon I already did that with masking...but I just want to know if there are any other options...anyways thanks for the reply.
Pavan Reddy
Revit Manager
Wed, Jul 1, 2009 at 5:33:10 AM | Pavan
4 Stars: 205 Votes
Quoting Pavan from 2009-06-30 23:33:25
"Hey Typhoon I already did that with masking...but I just want to know if there are any other options...anyways thanks for the reply."
Well, if you don't want this method, just create a slab and adjust the elevation point in the corners of the slab but you must create a "Filled Region" because the pattern of the earth between the 2 slabs....
Topo slopped pad (parking lot/road)
Mon, Aug 24, 2009 at 8:26:23 AM
Topo is struggling
Tue, Aug 15, 2006 at 9:24:01 AM
Topo surface/Building Pad problems b/w Existing and New Construction phases
Sun, Feb 6, 2011 at 12:28:27 AM
topo pad
Fri, Nov 14, 2008 at 6:50:59 PM
Building Pad Schedule
Wed, Apr 23, 2008 at 11:12:39 AM
Page generation time: 0.4246
