Forums >> Revit Building >> Technical Support >> Roof joins
Fri, Jul 29, 2005 at 12:43:22 AM | Roof joins
cadjockey
Hi all, I am trying to create a roof with a split pitch. I have created the roof in two parts and have joined them. However, the two segments do not seem to join seemlessly. Refer attached image. Have I joined the roofs correctly? cadjockey
Fri, Jul 29, 2005 at 12:04:14 PM | RE: Roof joins
JoeDrevitO
I would suggest turning on thin lines and making sure that the two edges are aligned, and then use join geometry on the roofs. Post edited on 2005-07-29 12:04:36
Fri, Jul 29, 2005 at 6:47:03 PM | RE: Roof joins
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Depending on the foot print, roof by extrusion might be the easier way to have this clean up. If you've got a gable or something then this won't be possible. The other option would be to set the edge on the upper roof to have a two-cut plumb edge with an fascia depth to match that of the lower. The only way to have it correctly mitre would be to have an in-place family do the work for the lower roof... That way you could make it the required profile to cleanup properly... HTH.
Roof joins for split level house
Wed, Apr 9, 2008 at 7:32:36 PM
Roof Joins for crickets on roof
Tue, Jan 12, 2010 at 2:36:02 PM
Can you make wall joins Miter by Default?
Wed, Dec 21, 2016 at 1:52:44 PM
14
Controlling roof and wall joins in revit 2009
Thu, Apr 9, 2009 at 10:09:40 PM
Joining a Floor to a Roof????? Help!
Sat, Mar 5, 2011 at 12:42:27 PM
Page generation time: 1.9277
