Forums >> General Discussion >> Revit Project Management >> Upgrading Files to new Revit 2010
Mon, Jun 29, 2009 at 6:16:24 PM | Upgrading Files to new Revit 2010
jgmas
Is there a plug-in, add-on or something out there that can be used to upgrades all the previous revit versions to the new version of revit at once or at least several at a time?
Mon, Jun 29, 2009 at 6:19:04 PM | Upgrading Files to new Revit 2010
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
There is a script somewhere.... possibly on the installation DVD? I have used it on previous releases but I forget where you get it.
Tue, Jun 30, 2009 at 2:37:05 AM | Upgrading Files to new Revit 2010
RevitSVA
RevitSVA Avatar
Have you found this and tested it yet?
If so can you let us know cause I would really like to change all the families .... as we currently have not received a family converter for 2010
Tue, Jun 30, 2009 at 10:22:45 AM | Upgrading Files to new Revit 2010
jgmas
No - I have not found it yet.
Tue, Jun 30, 2009 at 11:27:00 AM | Upgrading Files to new Revit 2010
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
http://revit.autodesk.com/pillar/custserv/web/service/support_4.0/faq/Installation/2_installation.asp
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Tue, Jun 30, 2009 at 12:07:54 PM | Upgrading Files to new Revit 2010
Brett - That link says 2002 at the bottom.  What versions does that convert?
Tue, Jun 30, 2009 at 12:22:40 PM | Upgrading Files to new Revit 2010
brettgoodchild
4 Stars: 17 Votes
Oops, guess that needs to be updated, my bad. I haven't checked to see if that would update the newest or not.
 Thanks for checking that.
I would just use the batch that's on the install CD
                             ~ Abraham Lincoln
Tue, Jun 30, 2009 at 2:14:13 PM | Upgrading Files to new Revit 2010
brettgoodchild
4 Stars: 17 Votes
Here is the batch upgrade from the 2010 disc.
                             ~ Abraham Lincoln
Upgrading Files From Revit 2008 to Revit 2009
Mon, Jun 23, 2008 at 7:35:59 AM
Upgrading from revit 2010 to 2012
Thu, Oct 27, 2011 at 7:19:24 AM
Upgrading Library too many .0001 files
Thu, Jan 18, 2007 at 1:28:32 PM
upgrading worksets to new revir version
Wed, Jan 11, 2006 at 6:11:05 PM
Upgrading Revit 2010 project to Revit 2013
Wed, May 23, 2012 at 1:28:20 PM
Page generation time: 5.3852
