Forums >> Revit Building >> Technical Support >> Vanishing Wall Sweeps
Mon, Jun 29, 2009 at 5:56:06 PM | Vanishing Wall Sweeps
cheryla
3 Stars: 2 Votes
I am having trouble with just one wall sweep, just on one view. It is visable when I look at it on the screen, but it won't print out.
I have checked the view proprties, and everything is on- nothing is turned off. I have two wall sweeps in the same view- one is printing, the other is not.
Any ideas? I will check this tomorrow morning when I get into work, so I won't be able to respond till then. Thanks!
Cheryl Nelson
Randall W. Hein Architects
Tue, Jun 30, 2009 at 4:00:59 AM | Vanishing Wall Sweeps
tim123
4 Stars: 19 Votes
Is the sweep the same as the one that is printing?  If so, try deleting it and putting a new one in.  If its different, place it in a different view and see if you have the same trouble.
If it's definitely the sweep in only that view you could create a new view (elevation?) and see if that solves it.
Tue, Jun 30, 2009 at 10:06:59 AM | Vanishing Wall Sweeps
cheryla
3 Stars: 2 Votes
I tried both of those things- there are two different wall sweep types. Because this is a minor thing, and we go out o bid at the end od this week, I will just draw a region instead and show it that way.
Thanks for your help though!
Cheryl Nelson
Angling Wall Sweeps
Walls with automatic wall sweeps
Fri, Aug 31, 2012 at 3:58:55 AM
Outlets and Wall Sweeps
Wed, Feb 29, 2012 at 9:39:46 AM
Wall sweeps line weight
Wed, Apr 30, 2008 at 10:59:05 AM
Wall Sweeps
Sun, Jul 12, 2009 at 1:54:07 PM
13
Page generation time: 1.5052
