Forums >> Revit Building >> Technical Support >> metal building question
Mon, Jun 29, 2009 at 5:54:51 PM | metal building question
bicke04
ok, i am working on a metal buidling.  I have went to the that steel website everyone suggests and downloaded the metal siding material i need.  now how do i go about loading it into my project to get it showing on my walls?
Tue, Jun 30, 2009 at 3:55:17 AM | metal building question
tim123
4 Stars: 19 Votes
What did you download? A family or a texture map.  If it's just a map then you will need to create a new material - is this what you mean?
Tue, Jun 30, 2009 at 7:07:27 AM | metal building question
MARS1276
1 Stars: 1 Votes
What is the website?  I too work for a company that design-builds metal-fabricated buildings.  So far for our wall panel we have simple assigned a material with a surface pattern to look like horizontal lines.  It's simple and effective; but I would like to look into the website further to see what they have to offer.
Tue, Jun 30, 2009 at 7:58:12 AM | metal building question
Try this one ... http://www.steelselect.com/resource_library/search.results.main.php?from=cad_library
Thu, Oct 15, 2009 at 9:51:35 AM | metal building question
mathdebater
mathdebater Avatar
5 Stars: 2 Votes
I also design pre-engineered metal buildings.
 I am able to import the 3d model of the building into revit and add textures to finish the building.
 Always looking for new textures and ideas.
Fri, Dec 20, 2013 at 8:39:28 PM | metal building question
mansell5
3.5 Stars: 4 Votes
regards installing the steel select revit texture library, i have just done that myself.
download/read their installation instructions that comes with the library.
you need to follow the installation instructions exactly.
pay attention to the pathing in the instructions.
all works well.
cheers
geoffm
Question for metal cladding sheet as curtain panel attached to slopped roof
Sat, Jul 24, 2021 at 8:17:45 AM
Pre-Engineered Metal Building
Wed, Mar 25, 2015 at 8:01:34 AM
Pre-engineered Metal Buildings
Thu, Feb 24, 2005 at 4:37:01 PM
Pre-Engineered Metal Building [ 1 2 ]
Tue, Sep 16, 2014 at 7:42:47 AM
17
Metal Deck profile question
Thu, Jun 1, 2017 at 11:16:20 PM
Page generation time: 0.3787
