Forums >> Revit Building >> Technical Support >> 2010 is slow
Mon, Jun 29, 2009 at 3:09:33 PM | 2010 is slow
keyaggie
My 2009 runs great and is fast.  But 2010 on my machine (64bit, Vista, 4G) is slooooww.  I get the little spinner wheel
for practically everything i do, anyone else have this problem?
Mon, Jun 29, 2009 at 4:02:17 PM | 2010 is slow
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
Check your graphics options and try it with hardware accelleration on and then try it off. 2010 performs a bit faster for me on my vista machine with 8 gb ram. With Vista 64 i would recomment more ram since the OS uses like 1.5 or something near there just to run.
Mon, Jun 29, 2009 at 4:20:44 PM | 2010 is slow
keyaggie
interestingly I read somewhere else, someone complained about having to up the machine for this release.
I will give your ideas a shot...Thanks!
Mon, Jun 29, 2009 at 4:26:45 PM | 2010 is slow
alabaster2513
3.5 Stars: 25 Votes
for me the 2010 release actually performs better on my older less powerful machines than 2009 becuase of the Direct3D improvements. Although a lot of others do seem to be having crashing and performance related issues.
Tue, Sep 22, 2009 at 1:53:07 PM | 2010 is slow
RainaMc
RainaMc Avatar
Did this work for you?  I have just done this and it tells me things may not show correctly.  Should I be concerned about it?
 Thanks,
RAC 2010 Slow after short time
Wed, Jan 20, 2010 at 4:13:41 PM
Tag dimensions to reference plane in 2010
Wed, Jan 6, 2010 at 1:41:42 PM
WHY THE A.REVIT BUILDING GOES SOOO SLOW?
Fri, May 4, 2007 at 2:43:19 AM
Topo Surface Edits Running EXTREMELY SLOW in 2010. Help :)
Mon, Jan 18, 2010 at 8:38:59 AM
revit running slow
Mon, Feb 15, 2010 at 2:40:52 AM
Page generation time: 0.1997
