12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> Lineweights Question
23 Posts No Rating |
Whenever I make anything in the Family Editor, the lineweights look great. But when a load into the project, the lineweights dissapear. Anybody know why?
Family line weights and project line weights have two different settings.
If you check the settings--> Line Weights in the family and the project you'll notice they'll vary...
Thanks.....
49 Posts No Rating |
Just to make sure it's clear. If you load a family into a project and the family has a line style which already exists in the project, it will not be overridden (this makes sense since if you were to change the lineweight of your windows for example, you wouldn't want that to be overridden every time you loaded in a new window). So if your family needs a different line style than the one currently in your project you need to create a line style in the family with a unique name, or change the line style in the project itself.
Cheers!
Lineweights Issue |
Thu, Nov 17, 2005 at 6:05:35 PM
Titleblock question |
Thu, Jul 2, 2009 at 4:23:14 PM
Revit lineweights |
Wed, Jan 28, 2015 at 9:31:49 AM
Revit Lineweights not printing correctly |
Fri, Jun 14, 2013 at 1:27:49 PM
revit 2008_ lineweights in 3d views vary. |
Tue, Apr 22, 2008 at 8:49:57 AM
