31 Users Online (29 Members):
Forums >> Revit Building >> Technical Support >> Combining Families
27 Posts No Rating |
I am creating several of the same object but with different features. There are basically cubes with holes in them. But each one has the holes in different spots. My question is do I have to make a new family for each one and if I do is it possible to combine all the families into one file so that someone doesn't have to load each one seperately.
You should be able to create a simple family for these and have parameters to control the positions of the holes.
Go to Family Types from the family editor and create new family types. Then just change the dimensional information for each type. This way when it gets loaded into a project the end user will have all the types loaded automatically...much like doors and windows. HTH
I tried that and the holes end up in every cube. Some have different sizes and a different number of holes
You need to control the visibility of the holes using a y/n paramter that you switch on/off in the types
Perhaps you could post an image of what you're trying to achieve. Do all the cubes have the same amount of holes? Are they all the same diameter? In any case you will be able to achieve this. You can have a parameter for the diameter and position of the holes.
If the holes... are different sized and in different locations in each type, you can do this with multiple holes switched on/off or one hole with different parametric locations and sizes.
30 Posts No Rating |
Load all your cubes into 1 generic model (or any other category) family. Inside that generic model, place all cubes at same locateion (one-over-another). Pick any one of them and select 'Label'-->Add Parameter and Name the parameter (such as "Cube Type). Save the family. Done! Try loading it in a project, select it and got to properties dialogue box. You should see a list of cube types under "Cube Type" parameter.
Combining Sloped and vertical Curtain Wall |
Wed, Jun 15, 2005 at 9:07:22 PM
Combining Two Revit Projects |
Mon, Jan 27, 2014 at 7:40:27 AM
Revit Families & Types |
Tue, Apr 9, 2013 at 6:53:43 AM
Schedules combining 2 text fields in to 1 |
Fri, Aug 10, 2007 at 12:27:28 PM
Combining Elevation Tags? |
Fri, May 18, 2018 at 9:39:23 AM
