Forums >> Revit Building >> Technical Support >> New to revit. Stacked wall question
Fri, Jun 26, 2009 at 10:36:46 AM | New to revit. Stacked wall question
xb4ax
I just started working in revit last week and I've got a model that I need to do over the weekend.  The front of the building is cladded in a metal panel system.  In some areas the paneling stops at aprox. 3' and has cap & slip-faced cmu below. What would be the best way to model this?  I was using a modified stacked wall, but i was not able to change the offset or thicknes of the cmu and the paneling above to be different.
 I can post a pic of what i'm talking about if need be, but the wall is metal stud, sheathing, 1.5" air space, & 4" cmu block below 3',  and metal stud, sheathing, then 2" deep panel system above 3'.
Any advice would be appreciated. Thanks guys.
-Matt
Fri, Jun 26, 2009 at 11:00:11 AM | New to revit. Stacked wall question
When you define a stacked wall, there is an offset setting for each portion of the wall.
Be aware that stcked walls have problems joining to non-stacked walls ... If you have a nice box, they are fine.
Fri, Jun 26, 2009 at 11:31:02 AM | New to revit. Stacked wall question
xb4ax
Where is this feature?  I'm not seeing that in the type properties, or the edit assembly window.  When i try to edit the wall the thicknesses are grayed out so i can't change them.. If i try and chage one in the section view, they both change.
Fri, Jun 26, 2009 at 11:37:17 AM | New to revit. Stacked wall question
xb4ax
Fri, Jun 26, 2009 at 11:37:26 AM | New to revit. Stacked wall question
tim123
4 Stars: 19 Votes
The stacked walls are made up of individual walls.  Go to the walls that make them up to change their properties.
Fri, Jun 26, 2009 at 11:39:40 AM | New to revit. Stacked wall question
Whoa ... when did windows come into this discussion?  You question seemed to be about the wall stack.
If you are placing windows in the stacked wall and they look strange because of how they cut the wall & trim out, you may have to play with which portion hosts the window.  Try a 3D view and experiment.   If you place a window that hosts in the thick portion of the stack, it may look strange where it crosses into the thinner area.  Place it in the thnner area then drag it down and see what happens.
Fri, Jun 26, 2009 at 11:44:04 AM | New to revit. Stacked wall question
xb4ax
ok, maybe the wall wasn't a stacked wall.. on the walls pull down menu it was listed under basic wall not stacked.. I modified an existing wall type that had several materials but apprently it wasn't actually a stacked wall, just had dif materials listed.
WWhub, i was refering to the "edit assembly" window that appears when you click the "edit" structure button.
Edited on: Fri, Jun 26, 2009 at 12:03:49 PM
Fri, Jun 26, 2009 at 12:05:55 PM | New to revit. Stacked wall question
I think you do want a stacked wall.  Read your HELP on "stacked" walls.
Fri, Jun 26, 2009 at 2:06:07 PM | New to revit. Stacked wall question
xb4ax
Alright, I've got my stacked wall set up and it looks really good.. the one thing that i'm now having problems with is that the metal stud & cmu wall on the bottom can't be set to 3' tall.. The height says variable and it won't let me change it. How do i set it up so that that wall is only 3' tall and the metal stud & panel wall on top goes up to the parapet? Is this something that i change in just the stud & cmu wall properties, or in the stacked wall properties?
Again, thanks for all the help.
Fri, Jun 26, 2009 at 2:09:29 PM | New to revit. Stacked wall question
xb4ax
ah.. never mind i just figured it out.. i just needed to set the other wall to variable instead.
Sat, Jun 27, 2009 at 7:40:44 AM | New to revit. Stacked wall question
#11
Good for you and thanks for posting what you found your problem was.
The best way to learn REVIT is through discovery because it helps you to understand how Revit works.  Once you get some of the fundamental thought processes down, the learning process really quickens.
stacked wall line visable on the wrong side?
Wed, May 6, 2009 at 10:51:58 AM
Stacked Wall Sweep Returns (RAC 2008)
Mon, Nov 5, 2007 at 8:49:08 AM
Can't Put Curtain Wall Inside Stacked Wall??????? Help Needed
Thu, Jan 24, 2013 at 8:06:06 PM
Scheduling of Stacked Walls
Tue, Aug 18, 2009 at 2:16:01 PM
Breaking apart a Stacked Wall Issue
Wed, Mar 11, 2009 at 12:03:44 PM
Page generation time: 2.8144
