Forums >> General Discussion >> Revit Project Management >> Archiving
Fri, Jun 26, 2009 at 10:20:31 AM | Archiving
erames44
In AutoCAD there is a way to e-transmit a file to be able to archive all of the links.  Is there a way to archive the model as a *.rvt file. and bind structural and MEP files similar to e-transmit so that it will preserve all models at the same point of design and preserve links without creating a bunch of extra work? Preserving the links is one of the main issues here. We can of course preserve each of the models separately and then go back and re-link to the archive model so that when opening the file later the model is accurately preserved. I am really looking for a one step process does anyone have any ideas?
Fri, Jun 26, 2009 at 10:36:50 AM | Archiving
Open the central detached and bind the links.
Fri, Jun 26, 2009 at 11:29:29 AM | Archiving
erames44
This will increase the file size correct? On large projects that are slow without binding how does this affect your ability to retrieve work?
Fri, Jun 26, 2009 at 11:33:31 AM | Archiving
I have not done this on large projects so you may have to experiment with this.  Look at what worksets are in the linked model and see if they transfer to like named worksets.  You may have to establish the workset first in the main model.
I would create two small projects and test this process first.
Archiving Projects
Wed, Jan 9, 2008 at 1:25:45 PM
Archiving Projects
Mon, Oct 3, 2011 at 11:59:15 AM
how to reduce size of file for archiving
Tue, Oct 24, 2006 at 2:35:52 PM
Archiving Revit for Drawing issue.
Wed, Aug 13, 2008 at 11:44:42 AM
Archiving Projects
Thu, Feb 14, 2008 at 8:27:51 AM
Page generation time: 0.0198
