Forums >> Revit Systems >> Technical Support >> Merging Projects
Thu, Jun 25, 2009 at 1:36:19 PM | Merging Projects
GMMcCrossin
I started a project in revit structural 2010 and drew the building and all the steel into it. Now I need to add my piping but i have a structural template. Is there anyway to open a structural project with a mechanical template or convert a structural template to a mep template?
 Basicly now i can open my project in mep but when i put pipe in it dose not work..........blah
Anything Helps
Fri, Jun 26, 2009 at 4:53:17 PM | Merging Projects
ScubaMan
You can make a mep file and then link the two files. (File>import/link>revit...) from there you can use copy/monitor (tools>copy/monitor>select link) if you want to move some of the structural steel from the mep file. If you just want move the structural things from the structural file the link will update when you save both the structural and mep file. i make the changes from both the files (i dont know what way works best).
Merging Shared Parameters
Mon, Jun 8, 2009 at 3:08:12 PM
Merging Toposurfaces
Tue, Apr 21, 2015 at 8:07:53 AM
Beam not merging
Mon, Mar 16, 2009 at 5:57:09 AM
Help Combining/merging 2 separate projects into 1
Thu, Oct 4, 2007 at 2:09:46 PM
Toposurface Help (Merging Surfaces) Road and Curbs
Tue, Jul 29, 2014 at 8:10:48 AM
Page generation time: 0.4325
