16 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> Central File Problem and importing problem
59 Posts No Rating |
Hi, Was wondering if anyone knew how to do this. I've been reading some other forums but I actually still don't get it. so I have this central file which i want to make a totally independant file from so I can play around in it. But for some reason everytime i detach from central file, save as a new name there always seems to be a central file after. but the thing is i'm reading that it makes its own central file. i understand this but now i can't move some of the objects because it says it can't obtain permission. problem #2: In this same file I am trying to imprt a autocad file so I can start working on the site with the autocad as an overlay. It doesn't seem to show up or Its there and I am not able to see it. Does anyone know how I can fix this problem as well. Thanks
----------------------------------- JD |
Once U enable worksets, there will always be a central file. When you open a central file detached, it is ppotentially a new central file but you need to save it as such. You can always then open this new central, work in it, then do a save to central then just quit out of it if you don't want a local. Linked files are linked. You can noty edit a linked CAD file inside REVIT. But you can edit it outside Revit then reload it in Revit.
element was deleted in central file |
Mon, Jun 15, 2015 at 12:22:46 AM
Central Model File locations - clouds Revit Arch 2015 |
Wed, Dec 6, 2017 at 10:10:53 AM
importing cad problem |
Fri, Mar 15, 2013 at 6:33:52 AM
Detaching file from central and working individually |
Mon, Jun 4, 2012 at 12:08:49 PM
CENTRAL FILE PATH NOT FOUND HELP HELP!!! |
Sun, Feb 22, 2009 at 12:35:49 PM
