Forums >> Revit Building >> Technical Support >> brick pattern not printing in elevation
Thu, Jun 25, 2009 at 10:03:45 AM | brick pattern not printing in elevation
beckyl
Revit 2010 - I have seen questions about this here but no answers that worked. Surface pattern of brick exterior walls (revit's standard brick w/CMU) is visible in all the views, but not printing. Any help would be much appreciated.
Thu, Jun 25, 2009 at 10:07:55 AM | brick pattern not printing in elevation
cbieser
1 Stars: 1 Votes
We are still using Revit 2009, but I've noticed that when we print with vector processing sometimes patterns don't print entirely, especially in 3D views.  Try printing using raster processing in the print setup and maybe that will fix it.
Shaded brickwork in elevation
Mon, Jun 25, 2012 at 8:03:58 AM
How Do I Make My Fill Pattern Show In 3D View
Tue, Jan 13, 2009 at 2:35:22 PM
Rendering - Brick looks like a stone pattern
Fri, Jun 17, 2011 at 12:48:59 PM
brick pattern not consistent
Wed, Mar 16, 2011 at 1:22:14 PM
Mixing of brick and block patterns and not aligning
Fri, Jun 23, 2017 at 9:40:16 PM
Page generation time: 0.9679
