Forums >> Revit Building >> Technical Support >> Level Elevation
Wed, Jun 24, 2009 at 2:46:02 PM | Level Elevation
bazar
bazar Avatar
I have a level with an elevation that reads 14' - 1 3/16", but the actually elevation is 14' - 53/256" so there is some rounding going on. My question is where can I control this. I am hoping to get it to read 14' - 1 1/4". I don't want to move the level, I just want to control the tolerance of the rounding. Any help would be greatly appreciated.
Wed, Jun 24, 2009 at 2:51:04 PM | Level Elevation
bazar
bazar Avatar
I forgot to mention that I'm using 2010...
Wed, Jun 24, 2009 at 5:04:04 PM | Level Elevation
Draft01
In Revit, go to the Help menu, on the index tab search: dimensions, units, custom.  There's a good explanation that I think will answer your question.
Thu, Jun 25, 2009 at 7:34:59 AM | Level Elevation
Pavan
Pavan Avatar
4.5 Stars: 3 Votes
Click on edit as shown in the Attachment 1.
Then select the Elevation label and click on  Edit Label as shown in Attachment 2.
 Then follow as shown in Attachment 3 and change the rounding to 1/4".
Load to the project. Done.
Pavan Reddy
Revit Manager
Intelligence is not always knowing the answers, it's always asking the questions.
Thu, Jun 25, 2009 at 8:12:59 AM | Level Elevation
bazar
bazar Avatar
Hey Pavan, I actually tried that already and it doesn't seem to work...
Thu, Jun 25, 2009 at 8:32:29 AM | Level Elevation
I don't understand why you would not want to correct this.  Where are you in this poroject that you can't set the elevation correctly?  You headed for other problems.
Beyond that .... If you did what Paven showed you, you should now have levels that are rounded to 1/4" - whatever that is.  His advice works.
Thu, Jun 25, 2009 at 9:23:00 AM | Level Elevation
bazar
bazar Avatar
Hello WWHub,
The elevation is currently set correctly. It was given the surveyed elevation. These elevations are in decimals, and this is where the small fractions come from. The project is in early CD's and if we move the elevation of the level up 1/16th it's just more work that really isn't worth it. The building will never be built to that precision. We were just trying to do a quick fix.
...and you would think doing what Pavan suggested (which was the first thing I did before even posting this thread) would work, but it didn't. Maybe I'm missing something...I'll try it again.
Thu, Jun 25, 2009 at 9:28:34 AM | Level Elevation
bazar
bazar Avatar
any other ideas?
Edited on: Thu, Jun 25, 2009 at 9:29:41 AM
Thu, Jun 25, 2009 at 10:21:58 AM | Level Elevation
I don't know what you have done because what Pavin posted works.  I did it!
Another solution:
Today's tip: Elevation base, Project Elevation vs. Actual Elevation | http://revittotd.com/06/340
Thu, Jun 25, 2009 at 12:51:44 PM | WWHub
bazar
bazar Avatar
Quoting WWHub from 2009-06-25 10:21:58
Another solution:
I think it's me...I must be doing something wrong. Thanks for the link...we are actually using shared coordinates so the basement is at 0'-0" (but it's sea level is actually 116'-4 41/128" ). I'll let you know when I figure it out
Edited on: Thu, Jun 25, 2009 at 2:02:59 PM
Tue, Jul 7, 2009 at 8:23:12 AM | bazar
#11
bazar
bazar Avatar
Quoting bazar from 2009-06-25 12:51:44
Another solution:
Edited on: Thu, Jun 25, 2009 at 2:02:59 PM"
What Pavan posted did work...it turns out I wasn't doing it properly before. Thanks Pavan
Tue, Jul 7, 2009 at 2:39:01 PM | Level Elevation
#12
aking05
In 2009 you would adjust the tolerance in the "project units" found in the "settings" menu.
Spot Elevation vs. Level elevation
Tue, Aug 19, 2025 at 1:06:15 AM
tURING OFF LEVEL LINE IN ELEVATION/SECTION
Sat, Mar 9, 2013 at 9:14:31 AM
Site Elevation to Floor Level Problem
Wed, Jun 27, 2012 at 11:42:30 AM
Elevation Level Override
Thu, Apr 5, 2018 at 1:22:35 PM
Level Coordination w/ Elevation View
Fri, Jun 14, 2013 at 4:31:48 PM
Page generation time: 4.1868
