Forums >> Revit Building >> Technical Support >> Multi Submittal Package in one Revit File
Wed, Jun 24, 2009 at 6:14:53 AM | Multi Submittal Package in one Revit File
thalim
Hi,Has anyone come across to have a different submittal package in one Revit file?We currently have a Foundaiton Permit Set, Foundation Bid Set, Building Permit Set and Building Bid Set. We want to maintain it in one Revit File.We created a Project Parameter for different submittal for View and Sheet:FPS = Foundation Permit SetFBS = Foundation Bid SetBPS = Building Permit SetBBS = Building Bid SetWe create a new Browser Organization by Submittal Package.Then, we duplicate each view with a prefix as listed above for each submittal as well as the sheet. For example:FPS - First Floor Plan in Vew. FPS-A-100 First Floor Plan in Sheet, but the border will still show Sheet A-100FBS - First Floor Plan in Vew. FBS-A-100 First Floor Plan in Sheet, but the border will still show Sheet A-100By doing that we were able to have a duplicate sheet in each submittal package.However, in the Plans, Elevations, or Building Sections, the Buidling Sections symbol, Wall Sections symbol, and Callouts symbol show the real sheet name which is FPS-A-100. I can't find a way to trick Revit to show the section as A-100.Any idea and help will be appreciated.Mahalo.Tobin
Wed, Jun 24, 2009 at 7:19:04 AM | Multi Submittal Package in one Revit File
tim123
4 Stars: 19 Votes
I don't think that you will be able to achieve what you're trying to do.  It would appear to me that you are doing this in a rather complicated manner.  If all the drawings are the same, perhaps what you could do is have a parameter on the sheets for each type of submission.  Just have one of each drawing and change the parameter when you print the drawings so that sheet A100 is A100 for all of them, but on the sheet it would read FBS A100.  Print the drawings and probably a record PDF set and then change the parameter to FPS and so on.
This would also substantially simplify your browser.
Link submittal data in revit 2012 or 2013
Tue, Jan 15, 2013 at 3:47:01 PM
Multi category tag in Revit 8.
Mon, Mar 27, 2006 at 10:33:20 PM
Problem with Multi Category tag
Mon, Apr 3, 2006 at 12:48:41 AM
Multi-level buildings
Tue, Feb 17, 2009 at 2:27:04 PM
Multi Family in Revit
Tue, Oct 21, 2008 at 9:03:19 AM
Page generation time: 1.4328
