Forums >> Revit Building >> Technical Support >> Merging Room Areas
Wed, Jun 24, 2009 at 5:19:30 AM | Merging Room Areas
Tim79
Hi there, I've looked around and can't seem to find this question anywhere else, so here goes....
I would like to include 2 technically divided spaces to be counted as 1 room with a combined area. The situation is that I have a bedroom with a cupboard constructed out of a plasterboard partition wall with a sliding cupboard door in it. Where I am working, habitable floor area for a room includes any cupboard space and any corresponding floor area occupied by any wall in between.
In the past I simply drew a closed polyline in AutoCAD ignoring the partition wall, but this kind of option does not appear to be available to room areas. Something like the sketch editor for a floor outline would be good if it existed, or something opposite to the room separation tool.
Thanks in advance for any advice.
Wed, Jun 24, 2009 at 5:27:33 AM | Merging Room Areas
tim123
4 Stars: 19 Votes
The wall has a property that makes it room bounding.  Uncheck that.
Wed, Jun 24, 2009 at 8:43:42 AM | Merging Room Areas
cbieser
1 Stars: 1 Votes
I also used to use the polyline tool for finding areas in AutoCAD.  A quick and dirty way to find an area in Revit is to draw a filled region and then open the element properties of it after you've finished sketching where you will find the area.
Mon, Jul 27, 2009 at 11:50:56 AM | Merging Room Areas
Tim79
Thanks tim123, that seems to have done it! My email notifications don't seem to be working, so I didn't realise until now that I had a reply.
room areas, room separations
Mon, Jun 2, 2008 at 8:19:42 PM
rooma area of several room areas
Mon, Apr 19, 2010 at 1:45:30 PM
Merging 2 Rooms - can it be done?
Sun, Apr 25, 2010 at 12:04:05 PM
room tags & areas
Fri, Mar 31, 2006 at 2:20:02 PM
Room Areas and Colour Schemes
Tue, Oct 21, 2008 at 3:51:29 AM
Page generation time: 0.1550
