18 Users Online (16 Members):
Forums >> Community >> Newbies >> Adding Material to Families based on Cad Imports
38 Posts No Rating |
Is it possible to add a material to the series of landscape rocks that are available on the site? They are imported cad dwgs when I open the family, so I don't see a way of adding material the normal way.
In Settings/Materials check if there are some material for that, OR Something like Render ###,###,###
Is this what you were referring to by ###,###,###? See Attached: All of them are set to default. So do I change those "Render Material ###,###,###" to give the rock material?
That is correct, you just need to assign the material to the correct RGB import from CAD. If your mesh of your rock is yellow, look for a ###-###-### that is yellow and assign the material to that one only.
And I also recommend to change the names i.e. Render Material 0,0,0 to Rock 1 or whatever.....
“Learning never exhausts the mind.” — Leonardo Da Vinci
yup...works like a charm....doesn't apply the material perfect, but works for the most part. Thanks fellas!
Materials Wrong when Rendering Families w/ 3d CAD Imports RA2008 |
Fri, Sep 21, 2007 at 7:45:27 AM
PLAN REGION PROBLEM |
Wed, Sep 10, 2014 at 10:27:01 AM
Remove hidden CAD imports |
Thu, Nov 6, 2008 at 9:32:16 AM
Grouping Line-based Families |
Mon, Oct 30, 2006 at 12:00:45 PM
lighting families |
Fri, Mar 26, 2004 at 9:18:45 AM
