Forums >> Revit Building >> Technical Support >> Combining two text parameters into one
Tue, Jun 23, 2009 at 2:03:49 AM | Combining two text parameters into one
MartinL
Hi everyone!
I'm trying to combine two text parameters into one parameter, and I just keep getting errors.I think it's quite easy, but still it wont work. I've made two shared parameters that contains text in form of letters and numbers.
For example one parameter might be "F1" and the other just "3", how can I make a parameter that combines these two into one that says "F13"?
Hope you know the answer.
Tue, Jun 23, 2009 at 6:27:44 AM | Combining two text parameters into one
You can't - sorry.
Schedules combining 2 text fields in to 1
Fri, Aug 10, 2007 at 12:27:28 PM
Shared Parameters Text File? Has anyone used this?
Tue, Jun 14, 2011 at 10:11:56 AM
Text TYPE PARAMETERS
Mon, Mar 19, 2007 at 8:46:40 AM
keynote text size wont match text size of project with same parameters
Mon, Nov 27, 2017 at 10:26:54 AM
text box leader alignment
Sun, May 9, 2010 at 7:48:44 AM
Page generation time: 2.9613
