Forums >> Revit Building >> Technical Support >> Moving walls and components
Mon, Jun 22, 2009 at 6:55:10 PM | Moving walls and components
pmedina
Lets say that i have built a house in revit (footing, foundation, flooring, exterior walls and interior wall). I decide i want to make the overall dimensions of the house bigger. How do i make it larger without having to individually change the dimensions of all the components such as the flooring system and the foundation walls? Is there a way to move exterior walls and also simultaneously move and keep the foundation walls/flooring/footing directly beneath it?
Tue, Jun 23, 2009 at 1:48:39 AM | Moving walls and components
tim123
4 Stars: 19 Votes
This depends on how the house is modelled.  If you had set up grid lines and constrained the walls to the gridlines, used the walls to define the floors and the roofs by footprint using the wall offset, you could simply move the gridline and everything should move with it.  Of course it depends on the complexity and what is constrained to the wall, but defionitely possible.
Tue, Jun 23, 2009 at 6:26:54 AM | Moving walls and components
Also, from a plan view that is full depth, you can window a portion of the building and "stretch" it to a new location.
The problem with both tim and my answers is that some elements are constrained to move in only one direction and the only way to move in the other direction is to "disconnect" your elements.  However, you are not only disconnecting model elements but all dimesions and tags as well.
Electrical components moving when reloading arch model
Mon, Jan 5, 2015 at 9:01:02 AM
Revit components popping and moving all over the place
Tue, Mar 22, 2016 at 3:58:37 PM
Locking electrical components to host
Wed, Mar 31, 2010 at 3:18:03 PM
moving walls
Tue, Aug 6, 2013 at 8:54:03 PM
Moving an entire plan
Mon, Oct 29, 2012 at 7:31:51 AM
Page generation time: 2.4492
