Forums >> Revit Building >> Technical Support >> Turn off Structural Elements in ALL Views of Project
Mon, Jun 22, 2009 at 12:56:35 PM | Turn off Structural Elements in ALL Views of Project
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Hello there,
I am trying to see if there is a way I can apply a filter or something to all my views to allow certain categories in our linked structural model to be off.  Right now I am having to go to visibility graphics and go inot the linked model and turn off; walls, roofs, floors etc.  All I really want is the structural columns, beams etc.
Is there a way to do this?
Thanks,
Lorne
Denver, CO
Revit Architecture
Mon, Jun 22, 2009 at 2:03:25 PM | Turn off Structural Elements in ALL Views of Project
You should be controlling this throughj VG in the main model - VG / Revit-links tab.  Change it in one view and create a view template from that view - assign the view template to all the other views that are set up the same then just apply the default view template.  Revit should have called this view property "assigned" instead of default.
Mon, Jun 22, 2009 at 2:08:13 PM | Turn off Structural Elements in ALL Views of Project
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Yea I was afraid this is the only method.  See a lot of our views us different view templates.  So I'd have to create one for each type of view template.  It's the method I've been using but still better than nothing.
Thanks WWHub.
Lorne
Denver, CO
Revit Architecture
Monitoring Non-Copied Structural Elements
Wed, Jun 25, 2014 at 10:27:34 AM
Worksets in structural projects
Mon, Jan 9, 2017 at 5:53:42 AM
Structural Symbols
Mon, Nov 13, 2006 at 9:54:48 PM
Structural Beams only show up in 3D views, + other problems.
Tue, Apr 5, 2005 at 6:27:21 PM
Structural elements are disjoined
Tue, Feb 8, 2005 at 5:17:37 PM
Page generation time: 1.0288
