17 Users Online (15 Members):
Forums >> Revit Building >> Technical Support >> Room Tag Visibility
6 Posts No Rating |
My office is working on a school addition/renovation, and would like to show the existing building at halftone settings for the Code Review. I created a filter and adjusted the line and pattern colors in order to get the existing workset to appear/print in an acceptable/readable gray (darker than halftone, but lighter than other walls). The problem comes with the Room Tags on the Exisiting Rooms. Although the lines/patterns on the exisiting portion of the building are the darker gray, the tags are still not dark enough. We want to make the room tags black like the tags on the new addition, while keeping the elements in the existing phase the gray color. I haven't been able to find an override in the visibility settings. I tried editing my filter, but "annotations" and "tags" or not checkable options include/exclude. Any suggestions? Or will I have to use the "change the filter/workset/phase on a duplicate drawing and overlay on sheet" method? Thanks in advance!
6 Posts No Rating |
Alright-- figured it out. I had apparently right-clicked, over-ridden graphics in view for each of the tags, and set them to half tone. Uncheck, probelm solved.
Visibility Parameter in Room Tag |
Fri, Jun 4, 2010 at 6:01:09 PM
Visibility elements in a room tag |
Mon, Aug 9, 2010 at 2:58:33 PM
Room tag not showing in only one room. [ 1 2 ] |
Sat, Sep 27, 2025 at 3:40:00 AM
15
HELP!!! Problems with Room Tag |
Tue, Dec 3, 2013 at 7:17:38 AM
Editing a room tag |
Thu, Oct 12, 2017 at 3:17:41 PM
