Forums >> Revit Building >> Technical Support >> Custom Wall Creation Question
Mon, Jun 22, 2009 at 9:33:34 AM | Custom Wall Creation Question
Xaquin
This may be impossible.  I don't know.
I'm trying to make a Corrugated Metal wall similar to:
http://mayang.com/textures/Metal/images/Corrugated%20Metal/corrugated_metal_warehouse_side_9181157.JPG
It's for a warehouse and while three of the sides are Corrugated Metal Siding on CMU (I made a mass for the Metal in those cases), one side is 100% corrugated metal siding from finished floor to underside of roof deck.  The problem I'm having is that I can't add a door into it or attach it to the underside of the roof deck without it being an actual wall.
I hope this post makes sense, but please ask away if I didn't put this right.  Or, even better, if anyone knows what I can do, I'd appreciate it a ton.
Thanks
Mon, Jun 22, 2009 at 9:36:10 AM | Custom Wall Creation Question
Xaquin
I'm using Revit 2009.  I have 2010, but really didn't like it after playing with it for a few days =/
Mon, Jun 22, 2009 at 9:45:58 AM | Custom Wall Creation Question
tim123
4 Stars: 19 Votes
I would use a curtain wall for this.  You can then insert curtain wall doors into the wall.  You can also create a custom curtain wall panel with the corrugated profile for the other panels.
If you had created the wall as a custom family in the wall category rather than a mass you would have been able to put a door in.
Mon, Jun 22, 2009 at 10:00:10 AM | Custom Wall Creation Question
4 Stars: 205 Votes
Me too, if it was in roofs or slabs it's different but in walls i think i use the Curtain wall panel to do this, instead a create-in-place....
Mon, Jun 22, 2009 at 10:02:35 AM | Custom Wall Creation Question
Xaquin
ahh I hadn't though of doing this as a curtain wall.  Thanks all =)
Fri, Jul 24, 2009 at 11:10:17 AM | Custom Wall Creation Question
Xaquin
I can't get this to work at all.  Everytime I try to make it into a curtainwall, the pattern stretches funny.  It will look perfect for one segment and then be completely flat until the final segment.  The only way to make it look right, that I can find, is to make the curtain wall the exact size as the original panel.
I'm using 2010 full time now =/
any advice would be greatly appreciated.
Fri, Jul 24, 2009 at 2:39:24 PM | Custom Wall Creation Question
4 Stars: 205 Votes
Attach the lines to the ref. planes and constrain the model, it will work...
Fri, Jul 24, 2009 at 2:41:46 PM | Custom Wall Creation Question
Xaquin
that looks good
I'll give it another try.
thank you sir =)
Custom wall creation problem
Wed, Dec 16, 2015 at 7:04:14 AM
Custom post creation.
Thu, Feb 12, 2015 at 2:56:01 PM
Loading a Custom Curtain Wall
Mon, Mar 8, 2010 at 1:24:47 PM
"Revit Help Image" Wall Creation
Thu, Jan 15, 2009 at 1:28:25 AM
custom wall type
Sun, May 12, 2013 at 8:31:38 AM
Page generation time: 0.7655
