13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> Massing
16 Posts No Rating |
I am using Revit Arch. 2009. My problem is I am unexperienced with massing. I can create a profile and a path and send my massing around but i need to create a profile in more than one plane. Is there a simple solution to this? Feel free to give me anything you have on Massing.... I have Rev. Arch 2009, and Rev. Structure,and MEP 2010
Your question is not clear. A profile by nature is only 2D and you can create that on any plane. 2009 allows you to extrude / revolve or sweep that profile along a 2d or 3d path and it will allow you to blend between two different profiles on parallel planes. But that it is it for 2009 - 2010 allows more manipulation if you need it.
I guess what i need to know is how do a create a work plane at a 45 degree angle to start my profile?
In either a family or in a project, goto an elevation view and draw your reference plane - then select it and in its properties, give it a name so that you can find it. BUT - Do you really want to do this. Most objects are easier to create in normal planes in a family, then by un-checking the "always vertical" parameter in the family settings, the family can be rotated in the project to the angle you want.
why my massing can't not be a solid? |
Fri, Feb 11, 2011 at 8:26:42 PM
conceptual massing...undulating roof shape |
Thu, Jun 24, 2010 at 3:01:55 PM
Finding Massing Model |
Wed, Feb 23, 2011 at 3:54:53 PM
>>>stuck with creating massing form in revit<<< HELP! |
Fri, Nov 6, 2009 at 4:07:53 PM
in place massing problems |
Thu, Jul 16, 2009 at 6:41:44 AM
