Forums >> Revit Building >> Technical Support >> Topographic Site
Wed, Jul 27, 2005 at 6:18:46 PM | Topographic Site
CADMS
I have my site contours as polylines with elevations. When imported into Revit, they just behave in a weird manner. I seem to loose some arcs. Are there any limitations that polylines have when they are imported. Please try with the attached file.
Wed, Jul 27, 2005 at 6:55:54 PM | RE: Topographic Site
eldados
eldados Avatar
4.5 Stars: 8 Votes
mate, I have tried your file and it works fine. do you "use imported" when you bring it in? I have attached the file, I used meters as my units, don't know if this is right though...
Wed, Jul 27, 2005 at 6:58:18 PM | RE: Topographic Site
TomDorner
4.5 Stars: 25 Votes
I wouldn't import any ACAD linework into Revit. For the site, it is best to create a Revit toposurface using the "linked" ACAD file. I believe there is a decent explanation in the Revit help/tutorials. HTH Tom
Wed, Jul 27, 2005 at 7:01:17 PM | RE:
eldados
eldados Avatar
4.5 Stars: 8 Votes
HTH
Tom
Smile I assume this is what he was trying to do... that's what I did with the file anyway. lol
Thu, Jul 28, 2005 at 1:59:39 PM | RE: Topographic Site
CADMS
Thanks. But, your Revit file seems to have the same problem as mine if you compare the contours to the 2D in AutoCAD.
Thu, Jul 28, 2005 at 3:40:59 PM | RE: Topographic Site
TomDorner
4.5 Stars: 25 Votes
The Revit site tools are for visual representation of the model for presentation and rendering purposes. Revit is not a civil engineering package and I wouldn't even attempt to show any site work in Revit beyond the conceptual stuff. Sometimes ACAD has its place and accurate site drawings is one of them. Tom
Thu, Jul 28, 2005 at 6:24:46 PM | RE: Topographic Site
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Contours lines can generally be located in numerous locations and still represent the same topography. In AutoCAD you specify where you want your contours to go. In revit, you plan out the topography and revit places the contours where it thinks they should go. I'd trust that they still represent the same topography... HTH.
Thu, Mar 5, 2009 at 9:21:17 AM | Topographic Site
JohanEkstrom
Sorry about waking up an old thread, but exactly how do you create the toposurface to follow the dwg?
 You import the dwg. Go to toposurface...and then?
 Probably a dumb question but im very new at topo.
Thu, Mar 5, 2009 at 10:29:51 AM | Topographic Site
Importing a topo surface or creating a topo surface are both explained clearly in your help.  Look using "site" as your search.  "Creating a Toposurface from Imported 3D Data"  will explain how to use a CAD file that has 3d points or 3d polylines.
TOPOGRAPHIC ELEVATION CHANGE
Wed, Sep 16, 2009 at 12:27:25 AM
Topographic points
Thu, Nov 27, 2008 at 9:22:44 PM
Hiding the edges of a topographic surface
Mon, Nov 3, 2008 at 10:44:15 AM
CREATE SITE TOPOGRAPHY USING SPOT ELEVATIONS?
Thu, Jun 28, 2012 at 3:52:17 PM
topographic subregions
Tue, May 23, 2006 at 11:43:54 AM
Page generation time: 0.1528
