Forums >> Revit Building >> Technical Support >> Nested Mullion Family Issues
Fri, Jun 19, 2009 at 10:27:51 AM | Nested Mullion Family Issues
kore24
So I downloaded a storefront curtain wall system from a manufactorer, and it mainly works.  The issue that I'm having is the nested profile (which contains the detail work) is not in the right place, see attached.  The detail work needs to be shifted to the right of where the mullion actually is because of the gap between the mullion and the wall.  So everything would be fine, but the basic profile lines are still showing even though I switched them to only show in a cource and medium views.  The nested detail work is set to only show in fine view, which it does.  Any thoughts?
nested annotation families in detail family not showing up?
Mon, May 10, 2010 at 9:11:20 AM
Trouble with Array Parameter within a nested family
Wed, Sep 12, 2012 at 5:19:16 AM
Text issues with generic annotation family nested into detail component.
Mon, May 19, 2014 at 11:27:43 AM
nested family rotation
Tue, Sep 3, 2013 at 1:25:41 PM
scale nested family within a family (2017)
Wed, May 3, 2017 at 5:28:43 PM
Page generation time: 3.9719
