Forums >> Revit Building >> Tips & Tricks >> Swept Blend Wall
Tue, Jun 16, 2009 at 10:27:39 PM | Swept Blend Wall
BillC
BillC Avatar
I'm trying to create a horizontally curved wall with a vertically curved top profile that will host a sheet metal coping.  Trying to use the swept blend with the spline option as the 2D path and it will only work with a simple spline of three nodes or less.  It seems there a limit to the amount of nodes for the path.
Once I get the wall, which I can't, will it host a sloped coping?  Or is there a better way to do this?  Thanks.
Sat, Jun 20, 2009 at 7:10:24 AM | Swept Blend Wall
4 Stars: 205 Votes
Hi, you don't tell what version of Revit you use but see this: http://www.megaupload.com/?d=RV9TKBD0
Sat, Jun 20, 2009 at 1:24:52 PM | Swept Blend Wall
BillC
BillC Avatar
Revit 9.  Can't open your file either.
Sat, Jun 20, 2009 at 2:32:15 PM | Swept Blend Wall
4 Stars: 205 Votes
"Revit 9.  Can't open your file either." - Well, this video i create in 2009, i don't get it, I can download the video and see, this is not a model....
Sat, Jun 20, 2009 at 2:56:33 PM | Swept Blend Wall
BillC
BillC Avatar
That was great.  Thanks for the video.  However, I would like the 2D path to be more complex.  Sort of like an 'S'.  And the top of the wall has to have a vertical bump.  Sort of like a bell curve.  Should that be several blends instead on one joined together?
Sat, Jun 20, 2009 at 3:36:01 PM | Swept Blend Wall
4 Stars: 205 Votes
Like what???? can you put some images of what you want so i can figured out????
Edited on: Sat, Jun 20, 2009 at 3:45:58 PM
Sun, Jun 21, 2009 at 6:07:07 AM | Swept Blend Wall
4 Stars: 205 Votes
More complex like curves shapes in elevation only in 2010....
Edited on: Sun, Jun 21, 2009 at 6:18:50 AM
Sun, Jun 21, 2009 at 6:34:04 AM | Swept Blend Wall
BillC
BillC Avatar
Thats EXACTLY what I was trying to do.  How did you do that?  Were you able to create the 2d path with more than one segment?  I tried the spline feature and i could not use more than 2 nodes.
Sun, Jun 21, 2009 at 7:25:14 AM | Swept Blend Wall
4 Stars: 205 Votes
Which one??? the first or the last image?? the first was in 2009, the last one was in 2010...
Sun, Jun 21, 2009 at 7:44:10 AM | Swept Blend Wall
BillC
BillC Avatar
THe last image.  Revit 9.  I don't have Revit 10 loaded yet.  Can you do that in Revit 9?
Sun, Jun 21, 2009 at 7:57:25 AM | Swept Blend Wall
#11
4 Stars: 205 Votes
NO, because the "curved shaped" in elevation.... only allow straight segments and it's not in Solid Swept blend but Solid Sweep....
Edited on: Sun, Jun 21, 2009 at 10:17:43 AM
Sun, Jun 21, 2009 at 12:13:32 PM | Swept Blend Wall
#12
BillC
BillC Avatar
Terrific.  I'll give it a try.  The previous video  was very helpful.
Tue, Jun 23, 2009 at 8:52:51 PM | Swept Blend Wall
#13
BillC
BillC Avatar
Still having trouble with the sweep at the top of the curved wall.  How do you get a complex curve in the vertical direction?
Wed, Jun 24, 2009 at 4:37:36 AM | Swept Blend Wall
#14
4 Stars: 205 Votes
Images of what you want, please....
Please help me with swept blend!!
Mon, Jul 28, 2014 at 3:31:14 PM
Swept Blend
Fri, Nov 28, 2008 at 4:39:26 PM
cannot rotate the reference plane of a swept blend
Tue, Feb 23, 2010 at 6:22:35 AM
swept blend with more than 2 profiles
Sun, Nov 18, 2012 at 5:21:23 PM
Swept Blend for Basin
Tue, Oct 31, 2017 at 3:38:16 AM
Page generation time: 1.0063
