Forums >> General Discussion >> Revit Project Management >> Showing multiple phases in one viewport
Tue, Jun 16, 2009 at 7:48:29 PM | Showing multiple phases in one viewport
aumber
I'm running Revit 2009. Is it possible to filter a view to show two phases in one viewport?
For example, my file contains 8 phases. I would like to show phases 1&3 in one viewport. Is there a way to achieve this?
Thanks
Tue, Jun 16, 2009 at 8:02:56 PM | Showing multiple phases in one viewport
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Technically, Yes, but not a good idea.  I
f you created a project parameter for the phase you could then create a filter to be able to control each individual phase independently.  (unfortunately the Phase Created and Phase Demolished fields are not accessible in filters, otherwise this would be a perfect solution).  I wouldn't recommend this as it adds manual co-ordination in having to ensure your "Phase" project parameter matches the actual "Phase Created" value...  You could do this using the API to ensure its always accurate, but I'm not sure of you API skills...
But, you could just overlay the two views on a sheet.  They will appear as if its only one view but technically its still 2.  (draw order can become an issue with this method)
Regards,
Chris.
Align Floors on Multiple sheets
Wed, Nov 17, 2010 at 3:26:28 PM
Topography over multiple phases.
Tue, Jul 22, 2014 at 5:10:33 AM
Demo Plan with multi phases
Tue, Jul 28, 2015 at 7:34:43 AM
Multiple Viewport Titles in same sheet
Wed, Jul 30, 2008 at 7:16:18 PM
How to show all new phases as new
Fri, Mar 7, 2014 at 11:59:09 AM
Page generation time: 0.5553
