Forums >> Revit Building >> Technical Support >> Rotating a Pattern File
Tue, Jun 16, 2009 at 4:55:26 PM | Rotating a Pattern File
mtelford
5 Stars: 7 Votes
I am trying to use a Wood Surface Pattern only in a Fill.  However, the Pattern file that i am using only has it with the grain running horizontally.  I need it to be vertical.  How can i change this?
Tue, Jun 16, 2009 at 8:08:44 PM | Rotating a Pattern File
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Your pattern must be a Model Pattern Type, so use your TAB KEY to select one of the lines and rotate it with the rotate tool....
Edited on: Tue, Jun 16, 2009 at 8:10:18 PM
Wed, Jun 17, 2009 at 8:35:34 AM | Rotating a Pattern File
mtelford
5 Stars: 7 Votes
That worked perfectly.  Thanks.
For those doing research:
Open the Fill Pattern File.  Go down to the particular pattern title.  When at the end of the title line, hit ENTER to create a new line.  Type ";%MODEL" - This will make the pattern fill able to be rotated as erland73 said.
 Keep in mind that i did this using an AutoCAD fill pattern file.  not sure if it works for other types or not.
Wed, Jun 17, 2009 at 11:05:47 PM | Rotating a Pattern File
Luckydug
3.5 Stars: 3 Votes
I had the same problem..followed your instruction but RVT gave me a syntax error when I imported the autocad pattern..any one else get this..following is the woodgrain scrip I was trying to convert to an editable model fill
*WDGRAIN, Natural Grain;%MODEL349.6952, 0.310,0.770, 6.082105,0.089443, 0.111803,-11.0685360.0000, 0.420,0.750, 1.000,1.000, 0.110000,-0.89018.4349, 0.530,0.750, 2.213594,0.316228, 0.094868,-3.067409172.8750, 0.620,0.780, -7.069980,0.124035, 0.080623,-7.981635174.8056, 0.540,0.790, -10.049468,0.090536, 0.110454,-10.934907194.0362, 0.430,0.800, 3.152963,0.242536, 0.123693,-3.9994129.4623, 0.390,0.770, 5.096369,0.164399, 0.060828,-6.021935353.6598, 0.450,0.780, -8.061501,0.110432, 0.090554,-8.964831185.7106, 0.540,0.770, 9.054838,0.099504, 0.100499,-9.949377168.6901, 0.440,0.760, -4.118439,0.196116, 0.050990,-5.048029354.8056, 0.220,0.760, -10.049468,0.090536, 0.110454,-10.934907348.6901, 0.330,0.750, -4.118439,0.196116, 0.101980,-4.9970390.0000, 0.430,0.730, 1.000,1.000, 0.120000,-0.88020.5560, 0.550,0.730, 5.383893,0.117041, 0.085440,-8.4585643.8141, 0.630,0.760, 14.035511,0.066519, 0.150333,-14.882963354.8056, 0.780,0.770, -10.049468,0.090536, 0.110454,-10.9349070.0000, 0.890,0.760, 1.000,1.000, 0.110000,-0.8905.1944, 0.000,0.760, 10.049468,0.090536, 0.110454,-10.934907354.8056, 0.110,0.770, -10.049468,0.090536, 0.110454,-10.9349070.0000, 0.000,0.780, 1.000,1.000, 0.060000,-0.9405.1944, 0.060,0.780, 10.049468,0.090536, 0.110454,-10.9349070.0000, 0.170,0.790, 1.000,1.000, 0.100000,-0.90010.3048, 0.270,0.790, -6.082105,0.089443, 0.111803,-11.0685365.1944, 0.380,0.810, 10.049468,0.090536, 0.110454,-10.934907354.8056, 0.490,0.820, -10.049468,0.090536, 0.110454,-10.934907354.8056, 0.600,0.810, -10.049468,0.090536, 0.110454,-10.934907351.8699, 0.710,0.800, -6.081118,0.141421, 0.141421,-6.9296460.0000, 0.850,0.780, 1.000,1.000, 0.150000,-0.850347.4712, 0.810,0.180, 5.097866,0.108465, 0.092195,-9.127349354.2894, 0.900,0.160, -9.054838,0.099504, 0.100499,-9.9493778.1301, 0.810,0.180, 6.081118,0.141421, 0.070711,-7.0003579.4623, 0.880,0.190, 5.096369,0.164399, 0.121655,-5.9611070.0000, 0.000,0.210, 1.000,1.000, 0.120000,-0.880350.5377, 0.120,0.210, -5.096369,0.164399, 0.060828,-6.021935201.8014, 0.180,0.200, -3.156821,0.185695, 0.053852,-5.331313192.9946, 0.130,0.180, -9.219240,0.074953, 0.133417,-13.208247352.8750, 0.920,0.180, -7.069980,0.124035, 0.080623,-7.9816357.1250, 0.920,0.180, 7.069980,0.124035, 0.080623,-7.9816350.0000, 0.000,0.190, 1.000,1.000, 0.080000,-0.920194.0362, 0.080,0.190, 3.152963,0.242536, 0.082462,-4.040644356.6335, 0.220,0.220, -16.031112,0.058722, 0.170294,-16.859093357.7094, 0.390,0.210, -24.020791,0.039968, 0.250200,-24.7697923.1798, 0.640,0.200, 17.029296,0.055470, 0.180278,-17.8474799.4623, 0.820,0.210, 5.096369,0.164399, 0.182483,-5.90028010.3048, 0.000,0.120, -6.082105,0.089443, 0.111803,-11.06853615.9454, 0.110,0.140, -4.120817,0.137361, 0.145602,-7.1345080.0000, 0.250,0.180, 1.000,1.000, 0.130000,-0.870351.8699, 0.380,0.180, -6.081118,0.141421, 0.141421,-6.9296463.5763, 0.520,0.160, 15.033167,0.062378, 0.160312,-15.870907351.2538, 0.680,0.170, 7.070659,0.076029, 0.131529,-13.021417345.9638, 0.810,0.150, -3.152963,0.242536, 0.123693,-3.9994120.0000, 0.930,0.120, 1.000,1.000, 0.070000,-0.930174.8056, 0.220,0.220, -10.049468,0.090536, 0.220907,-10.824454355.2364, 0.000,0.280, -11.045049,0.083045, 0.240832,-11.8007630.0000, 0.240,0.260, 1.000,1.000, 0.230000,-0.7704.0856, 0.470,0.260, 13.038210,0.071247, 0.280713,-13.7549550.0000, 0.750,0.280, 1.000,1.000, 0.250000,-0.7507.1250, 0.000,0.070, 7.069980,0.124035, 0.241868,-7.8203906.3402, 0.240,0.100, 8.061501,0.110432, 0.181108,-8.874277357.5104, 0.420,0.120, -22.022673,0.043437, 0.230217,-22.791512353.4802, 0.650,0.110, -26.172489,0.028387, 0.352278,-34.8755523.0128, 0.000,0.720, 18.027680,0.052559, 0.190263,-18.836035351.8699, 0.190,0.730, -6.081118,0.141421, 0.212132,-6.858936357.6141, 0.400,0.700, -23.021691,0.041631, 0.240208,-23.78061610.6197, 0.640,0.690, -11.180171,0.061430, 0.162788,-16.1160320.0000, 0.800,0.720, 1.000,1.000, 0.200000,-0.800356.8202, 0.000,0.840, -17.029296,0.055470, 0.180278,-17.8474796.0090, 0.180,0.830, -10.049739,0.052342, 0.191050,-18.9139236.7098, 0.370,0.850, -9.055197,0.058421, 0.171172,-16.946070354.2894, 0.540,0.870, -9.054838,0.099504, 0.200998,-9.848878347.9052, 0.740,0.850, -9.219280,0.069843, 0.143178,-14.1746439.4623, 0.880,0.820, 5.096369,0.164399, 0.121655,-5.9611073.8141, 0.000,0.650, 14.035511,0.066519, 0.150333,-14.882963347.1957, 0.150,0.660, -13.341590,0.044324, 0.225610,-22.3354180.0000, 0.370,0.610, 1.000,1.000, 0.250000,-0.7505.4403, 0.620,0.610, -11.045259,0.047405, 0.210950,-20.8840736.7098, 0.830,0.630, -9.055197,0.058421, 0.171172,-16.9460700.0000, 0.000,0.910, 1.000,1.000, 0.170000,-0.8308.1301, 0.170,0.910, 6.081118,0.141421, 0.282843,-6.788225357.6141, 0.450,0.950, -23.021691,0.041631, 0.240208,-23.780616354.4725, 0.690,0.940, 21.094999,0.032108, 0.311448,-30.8333756.8428, 0.000,0.000, -17.117197,0.039715, 0.251794,-24.9275630.0000, 0.250,0.030, 1.000,1.000, 0.280000,-0.720356.3478, 0.530,0.030, -31.064442,0.021233, 0.470956,-46.6246910.0000, 0.000,0.350, 1.000,1.000, 0.240000,-0.7604.7636, 0.240,0.350, 11.045049,0.083045, 0.240832,-11.800763358.1524, 0.480,0.370, -30.016645,0.032241, 0.310161,-30.705964357.2737, 0.790,0.360, -20.024928,0.047565, 0.210238,-20.813558354.8056, 0.000,0.510, -10.049468,0.090536, 0.220907,-10.8244540.0000, 0.220,0.490, 1.000,1.000, 0.320000,-0.6801.9092, 0.540,0.490, 29.017217,0.033315, 0.300167,-29.7164953.5763, 0.840,0.500, 15.033167,0.062378, 0.160312,-15.870907
Thu, Jun 18, 2009 at 12:13:16 AM | Rotating a Pattern File
erland73
erland73 Avatar
4.5 Stars: 85 Votes
The correct form is:
;%TYPE=MODEL
349.6952, 0.310,0.770, 6.082105,0.089443, 0.111803...............
Rotating pattern on flooring
Fri, Apr 18, 2008 at 10:15:08 PM
Model Surface Pattern Skewed
Thu, Nov 6, 2014 at 4:05:24 PM
Rotating a fill pattern
Thu, Dec 1, 2011 at 2:58:28 PM
Pattern file location on drive
Wed, Mar 18, 2015 at 12:26:06 PM
Rotating Symbol geometry without rotating leabel
Wed, May 6, 2009 at 8:33:58 AM
Page generation time: 0.7938
