Forums >> Revit Systems >> Technical Support >> Piping problems
Tue, Jun 16, 2009 at 11:42:35 AM | Piping problems
revit7777
I am using revit 2009 MEP. I have drawn in some gas piping, it is within the view range, it has not been set to not show up in the overrides, but for some reason, it won't show up on the drawing. If I create a section view, it will show up within that, but not anywhere else. I have also checked that light bulb that shows hidden items, but it won't even show up there. Has anyone expierienced this before?
Tue, Jun 16, 2009 at 11:47:22 AM | Piping problems
Mattman2248
Mattman2248 Avatar
Did you check the visibility graphics?  If you are drawing in a mechanical sheet and the view template is mechanical, then most likely the piping has been turned of in the visibility graphics (VG).
 Matt
Revit was once a 5 letter swear word for me....
Piping loops
Wed, Apr 30, 2008 at 12:35:59 PM
Connecting Sanitary Piping
Thu, Dec 13, 2012 at 3:42:23 AM
Adding materials to piping systems
Mon, Oct 12, 2009 at 4:07:42 PM
Red lines around piping, System types
Mon, Jun 8, 2009 at 4:45:43 PM
REVIT for process piping spool drawings?
Mon, Mar 5, 2012 at 1:54:09 PM
Page generation time: 1.5834
