Forums >> Revit Building >> Technical Support >> EXPORTING
Tue, Jun 16, 2009 at 11:11:41 AM | EXPORTING
Bimman
Bimman Avatar
1 Stars: 2 Votes
I am exporting files to dwg and my crop region becaomes a viewport and is turned on in the new dwg file.  Is there any way to export with the crop/viewport off so I do not have to go into each sheet and turn it off.
PWD
Fri, Jun 19, 2009 at 5:53:38 AM | EXPORTING
line
yes, we are having similar issues. Because when printing you have the option to turn off the crop box. This option is not there in the export options. Also I tried to make an export layer with 0 thickness for the crop box but that did not work either (export as hidden layer). So we are using a program called scriptEese to turn off the layer in cad (another kind of lisp file)
maybe someone else has a better solution.
Dimensions and Exporting
Fri, Nov 9, 2007 at 2:30:26 PM
Exporting Sections to AutoCAD
Thu, Jun 16, 2005 at 4:53:41 PM
Exporting FBX from
Thu, Jul 22, 2010 at 12:36:28 PM
3D DWF Exporting in 9.1
Wed, Feb 7, 2007 at 3:39:28 AM
Exporting views for DWG
Thu, Oct 24, 2019 at 5:52:23 PM
Page generation time: 0.3735
