20 Users Online (18 Members):
Forums >> Revit Building >> Technical Support >> Cylinder with a angle
4 Posts No Rating |
Can someone help me create a eucaliptus pole for a thatch roof? It must be a cylinder with 150mm in a 45º...i have being trying but cant align the cylinder form to my reference planes and cant give the necessary angle to it. thanks
You can do it in a few ways. Edit the family and click on the pole. Click on the blue restraint lock and you should then be able to rotate it. Or align your workplane to the reference plane and then extrude it (see set work plane). Or create the pole using a sweep rather than an extrusion.
4 Posts No Rating |
I still dont understand...can you especify a bit more?
How did you create the pole?
4 Posts No Rating |
I made the circular profile in plan level and extrude it. But the problem is the constrains when I want to make it at 45 degrees. I could do a fixed one at 45º but then it wont be parametric. And a thatch roof as different angles.
If you created it as a family it may be constrained to be verical - see image.
4 Posts No Rating |
Thank you for your help but I cant do it. Going to make a fixed family without the parametric propoerties. Its not the best but works.
Truncated cylinder? |
Fri, Aug 1, 2014 at 7:04:47 PM
having trouble creating a truncated cylinder |
Wed, May 9, 2007 at 4:11:33 PM
Rotation angle of double angle roof bracing. |
Mon, Jan 21, 2008 at 2:51:55 PM
Adjustable Angle Reference Gets Lost once a 90 Degree Angle is Formed... |
Wed, Sep 30, 2015 at 12:28:52 PM
Editing a family created by a company |
Fri, Feb 14, 2014 at 9:07:20 AM
